If i was to swap my lucas pump over to a bosch do you need any other bits like throttle cable etc?
You can use the Lucas throttle cable with the bosch pump. Same with the bracket.
you need lines and injectors...
Along with the pulley pulley nut and woodruff key
and possibly some leakoff pipe
Best change the timing belt, tensioner a and all other thing whilst your at it
