I apologise if this is in the wrong section however I was unable to post in the parts wanted section. I've been looking for hours and can't source any of this braided pipe for my break system.
Anyone have any links to where I can purchase some?
Any motor factor should be able to supply some vacuum pipe in the appropriate size.
Cheers guys! I guess I was just searching for the wrong thing
Yeh, it's the pipe that connects the vacuum pump to the metal pipe that runs along the bulkhead.
It's spelt "brake", that might help your search.
(10-02-2014, 08:13 PM)Poodle Wrote: [ -> ]It's spelt "brake", that might help your search.
I was guna point that out...but Im trying to break habits!
Didn't read the other responses tbh, just imagined the poor guy had been shouting at ebay because it kept showing him broken pipes when all he wanted was brake hose.
Not going to start a new thread as I don't want to clutter the board so I was wondering if you guys could help me with finding a few things. I'm going to have a crack at changing the servo myself and the Haynes manual tells me I need to replace a few things but I can't find them anywhere.
I'm after a master cylinder 'O' ring, a check valve sealing grommet and a servo mounting gasket. Any help is hugely appreciated!
Make sure it's the appropriate hose you buy. Anything substandard could suck in on itself.
