Full Version: Turbo to downpipe bolts
It really fucks me off having to hold the bolt on the top while undoing the nut from underneath
Can I weld the bolt into the elbow so I can just undo the 10mm nuts from underneath
Or do they need to be able to move?
Cheers
Thats what ive done on mine
Out the welder comes then
Not sure if they needed to move with engine movement
The only down side is if you snap a bolt why tightening it up, will be a ball ache to sort Wink
I've welded it up with a nice juicy bolt none of that 8mm thick shit bolt pug put in Wink
Standard downpipe FTL!
