28-08-2013, 02:33 PM
28-08-2013, 02:35 PM
Bled the fuel system?
28-08-2013, 02:37 PM
(28-08-2013, 02:35 PM)Tom Wrote: [ -> ]Bled the fuel system?
Still useless round engines so how exactly? (even though i took a dturo out of a breaker i got!! Cant wait to drop it into my nad )
28-08-2013, 02:38 PM
fueling
stop solenoid
you only really need fuel, air and compression. Triple check air flow and fuel flow is sufficient
crack off the unions one turn on the injector lines (injector end), and crank the engine til it pisses out the top, lock the unions back tight, make sure all 4 bleed fuel out
fueling
stop solenoid
(28-08-2013, 02:37 PM)Darren123 Wrote: [ -> ](28-08-2013, 02:35 PM)Tom Wrote: [ -> ]Bled the fuel system?
28-08-2013, 02:57 PM
(28-08-2013, 02:38 PM)ginge191 Wrote: [ -> ]^^^^
fueling
stop solenoid
right we'll check the fuel flow how do we check the air flow?
28-08-2013, 02:58 PM
(28-08-2013, 02:57 PM)Darren123 Wrote: [ -> ]right we'll check the fuel flow how do we check the air flow?
easiest; disconnect any intercooler/piping and leave the inlet manifold open where the top mount usually sits. Obviously make sure there's nothing around it to get sucked in
and TBH, it's easiest way to get to the unions also. just leave any intercooler/turbo disconnected from the inlet
28-08-2013, 03:02 PM
fair enough and what am i looking for when we disconnect um? just to make sure there's an air flow?
28-08-2013, 03:09 PM
yeh, you can feel the inlet sucking...
just crack the unions off half a turn from tight, turn engine over, watch diesel piss out, tigten them up.
If they don't bleed fuel, tighten them ALL up and undo one line at a time
28-08-2013, 03:13 PM
Crack em all off hold it at full throttle and crank over til its squirting everywhere, tighten then start aha
28-08-2013, 04:31 PM
If the bleeding doesn't work check the stop solenoid on the pump. Are you going Lucas ----> Bosch?
13-09-2013, 01:12 PM
Crack one of the injectors off and turn the car over and see if fuel comes out
13-09-2013, 02:31 PM
What pump is on the new motor, if its lucas, and it still has an immob chip on it, it wont work out the box.
If its bosch / the same pump as old engine, just needs bleeding as above
13-09-2013, 04:43 PM
(13-09-2013, 02:31 PM)darrenjlobb Wrote: [ -> ]What pump is on the new motor, if its lucas, and it still has an immob chip on it, it wont work out the box.
On the Lucas stop solenoids, are they a simple change or is there more to it?
13-09-2013, 07:26 PM
The immob ones are covered with a steel shroud, you can cut the shroud off and either change the solenoid, or wire the one thats there manually, but you cant just swap complete immob lucas pumps as the chip on the back of the pump wont match the cars immob, so it wont open the solenoid.
15-09-2013, 11:06 AM
(13-09-2013, 07:26 PM)darrenjlobb Wrote: [ -> ]The immob ones are covered with a steel shroud, you can cut the shroud off and either change the solenoid, or wire the one thats there manually, but you cant just swap complete immob lucas pumps as the chip on the back of the pump wont match the cars immob, so it wont open the solenoid.
This is what is was all sorted now
15-09-2013, 11:09 AM
Thought as much lol.
29-09-2013, 01:52 PM
