I was gonna say! I know they say its going to snow like f*ck but already?!
Im liking your plans though. Not considered going balls out on some kind of GT** ball bearing turbo?
(14-10-2013, 03:42 PM)Tom Wrote: [ -> ]I was gonna say! I know they say its going to snow like f*ck but already?!
Both those IHI turbos I picked up the other day are ball bearing :-D
Not much being going on with this recently so I took it to the Xmas meet in Milton Keynes to give just for the sake of getting to drive it. Took massive overkill of tools but the rallye didn't miss a beat. 300 miles of epic bwarps and popping flames
266mm brake conversion, had to grind some of the caliper off to get them to fit but a massive improvement over the original milk bottle tops of brakes. Brakes completely fill the 14"wheels now. Also fitted braided lines while I was at it.
awesome pic...
needs to be new sig for sure!!
I did 300 miles too at weekend with GT not missing a beat...even with a boot full of tools n parts in case!!
what bit needed grinding off pal, I doing the nad brakes soon
(02-12-2013, 12:36 PM)Piggy Wrote: [ -> ]awesome pic...
On the 106 hub there's a curved bit that means you can't line the top carrier bolt up. Need to grind the top corner flat yoke so it clears the hub and you can bolt it on. You'll see what I mean when you do it. Just have a few cutting discs ready. Bit of getting used to required with big brakes on original servo but when you're used to them it's great
(02-12-2013, 12:51 PM)Piggy Wrote: [ -> ]lol...long travel??
Yeah, the 106 servo is so small that it now feels almost unassisted. Certainly builds leg muscle now haha
Another awesome picture :-) man I love this car
prefer the one on the road moving...looks ace.
Get that thing boosted!!!!
Beyond jealous of this car
(02-12-2013, 03:46 PM)vlj Wrote: [ -> ]Beyond jealous of this car
Haha thanks?
So a few things have happened since its trip to Milton Keynes, the main event being that it broke haha
Few highlights:
266mm brakes and braided lines are a massive improvement over the original milk bottle tops
Took it to work on a rare dry day
It broke down at the petrol station
So it's back to the workshop. Again. Lol
It was the idle control valve that broke, the valve is a plunger on a threaded shaft with a spring to keep tension on the plunger. The thread on the shaft has somehow been damaged meaning it was stuck fully open, cue a nice 4000rpm idle lol.
Since its cold and shit outside at the moment, it's locked away waiting for the new seats to be fitted, possibly a simple roll cage, rust on the sill and boot floor to be addressed, inner wings painting as surface rust treatment and maybe some new bilstein b8s
Oh, and because I found it cheaper than a new idle control valve, I've got a Citroën c2 vts alloy inlet manifold and a clio 172 throttle body waiting to go on. Should see a few more horses eh :-D
I know that petrol station...oppo halfords?
Handy open all hours place that
(31-12-2013, 02:26 PM)Piggy Wrote: [ -> ]I know that petrol station...oppo halfords?
Haha yeah. That's the one
Something awesome came in the post today :-D
Better than Xmas haha
Oooo C2 vts mani...
Whats that guna help with?
(06-01-2014, 06:57 PM)Piggy Wrote: [ -> ]Oooo C2 vts mani...
Aluminium inlet manifold instead of the shitty plastic one that leaks, the plenum is twice the size and the throttle body is bigger.
The inlet side of the engine on a vts is the only difference between the 125bhp engine and the 110bhp.
And it's shiney
A little late to the party i know, but surely you can do better than that sig zakk?!
How about this:
You're welcome.
Good work btw, love this motor, well saved.
No worries, that looks much better!
will the manifold just fit and work? or does it need to be mapped in? (#petroln00b
(07-01-2014, 09:24 AM)mr_fish Wrote: [ -> ]will the manifold just fit and work? or does it need to be mapped in? (#petroln00b )
That's what I'm yet to find out, just going to bolt it all on and see how it runs, but I guess some mapping will be required at some point to utilise the new set up.
If it runs as well as it was then that's good enough for now, start looking at more shinies then to make it worth the money for mapping haha.
I'm in half a mind to drop the engine out while it's having all this work done, clean up the spots of surface rust starting on the inner wings and bulkhead and just general bay tidying really :-)
I'm aiming to have this at "stage 2" kind of area by Pugfest, so that's going to be ported and polished inlet (get that sorted before the manifold goes on), 743 catcams and a remap.
Should see about 150bhp which is the general limit of stock management and fuelling. 7800rpm rev limit too :-P
Stage 3 is where I start looking into head work, aftermarket management and fueling etc
(08-01-2014, 04:18 PM)jammapic Wrote: [ -> ]Tasty little motor!
Thanks man :-)
Hoping to restore it back to mint condition with a bit of poke, sadly been neglected a bit by previous owners :-\
Decided now would be a good time to start tidying up the rallye, the weather's shit and the tax is about to run out so may as well get ready for spring :-)
First job, removing the old plastic inlet manifold and preparing for fitting the new aluminium setup
[attachment=12896]
Some comparison shots of the plastic and aluminium manifold and plenum , pretty obvious why it's an upgrade
[attachment=12897]
And some workshop pictures. Needs less mini and more pug aha
Oh shit someones nicked my wheels!
Some progress for anyone who cares
The Citroën c2 vts throttle body is a no go on this engine as it is controlled electronically rather than by cable, so that's gone on eBay.
Now for an interesting bit after some research, I'm planning to now use a clio 172 throttle body, it's slightly larger than the current j4 one, but has the useful feature of being cable operated, so should be as simple as making an adapter plate to fit the aluminium plenum stud pattern. Just need to find a decent price clio throttle body now....
Lots of research being going on in my free time, planning ahead for forging my block and raising the compression....
Some interesting differences between the j4 and jp4 engines
J4 has a stronger bottom end, thicker conrods and proper gudeon pins, while Peugeot Lightened the bottom end of the jp4 for a higher rev limit, but a downside of this, press fittings on everything, so pita to upgrade separate components.... More on that in the future.
Found out by checking serial numbers while it's been on the ramp that I'm running bilstein b8 shocks all round which was a pleasant surprise
Some painting has being going on too, scuttle panel going satin black, plus bits like the ecu tray and wiper arms etc
[attachment=12936]
Keep up the good work buddy...
Cant wait for the
upgrades
Looks good! Seen a 106 using 172 throttle body with the c2 manifold before. Good to know the j4 is stronger as thats whats going in my 205 lol
(20-01-2014, 10:28 AM)Craigus Wrote: [ -> ]Looks good! Seen a 106 using 172 throttle body with the c2 manifold before. Good to know the j4 is stronger as thats whats going in my 205 lol
You wouldn't have happened to notice how it was attached did you? Some people say adapter plate, others say drill and tap the manifold
