How can I return the pump to standard position? I have no idea what fueling it's at etc so would really like to be able to set it up properly
What amount of thread is visible at a standard on the fuel screw?
(20-06-2013, 12:54 PM)Matt Wrote: [ -> ]How can I return the pump to standard position? I have no idea what fueling it's at etc so would really like to be able to set it up properly
you can't mate . . . . just set it up best you can, why would you wanna go standard? . .
Return to standard so that I can turn the fueling up and know how many turns has been done
Just turn the boost up so it doesnt smoke any more? Job jobbed.
(20-06-2013, 01:20 PM)Matt Wrote: [ -> ]Return to standard so that I can turn the fueling up and know how many turns has been done
doesn't make any sense mate . . . . .all you need to know is how much psi your turbo is making and whether it's burning clean on full chat or not, all the other bits are fine tuning . .x
I must have made a hash up of some info somewhere. Sure I read somewhere 1/2 to 1 full turn of the screw if good. And the turn the turbo up. Add fuel till it coals, then back it off?
Wastegate, then fuel. Think of it like saturating the air you produce with fuel. You can hit 20psi fine, but without much fuel. Then just turn the fuel up until you get a slight haze on boost. You'll still be making 20psi just with more fuel and therefore more powaaah.
Think you're thinking of the ol' "stage 1" style tune like on Darren's video, when people played it safe by counting turns etc. Counting turns gives you a good rough idea of what's going on but the best way to do it is turn some screws and get driving.
Matt, if you want a mild tuning, gareth can help you out, he tuned up his bosch when it was running in his rover. had some good results
Sweet Ill give Gareth a message tonight and see when he is free
(20-06-2013, 01:55 PM)Matt Wrote: [ -> ]Sweet Ill give Gareth a message tonight and see when he is free
good man; he knows to gimmie a call if he's forgot
Haha I kinda know the ins and outs of it now, just need someone to give me a hand looking at things while I turn things lol
feel your pain; i asked niall over the other week whilst i changed a starter motor, he gives me the confidence to do it!
Haha I'm very technical it's the twisty but in the middle the the metal bit! Has two twisty bits makes more things fall off your car!
Haha yeah I have no confidence with this engine I know in theory what I need to do so need someone with me to tell me I haven't broke it
I can kinda sympathise with you matt, even though I'm still only using the crappy lucas pump. I'm pretty sure the waste gate on mine is giving up, as i seem to be lacking the boost it used to have, added to the fact that the old girl does seem to smoke quite a bit on full chat now.
Mine smokes a lot, Samass turned the turbo up, but then told me after he can't remember which way he turned it lol, so I'm gunna turn the turbo up and fuel etc and see what happens, give it a service and crack on!
I just need someone to watch me, and help when I adjust the hot/cold idle and try and sort my throttle cable. Need a girl with me too as my hands are too huge to fit most places in the engine bay haha
(20-06-2013, 03:07 PM)Matt Wrote: [ -> ]Mine smokes a lot, Samass turned the turbo up, but then told me after he can't remember which way he turned it lol, so I'm gunna turn the turbo up and fuel etc and see what happens, give it a service and crack on!
narr it's your tiny penis that's made you think your hands are big . .
(20-06-2013, 03:53 PM)Matt Wrote: [ -> ]
where you from matt?
From Isle of Wight, it's okay I know how, was just wondering if anyone knew the exact measurement etc
This may help you for approximately adjustment.
