14-08-2013, 08:36 AM
Also, the thermostat can stick closed. The engine will get hotter and hotter, destroy the headgasket but only show normal operating temp on the dash gauge. This is what my mums did!
JP
JP
(14-08-2013, 06:44 AM)Jonny81191 Wrote: [ -> ]Well if it handles anything like a TF then write your will now before you go near a track. Had a hoon in a TF last night and was massively dissatisfied with it. And I set off with low expectations. Got it sideways and held it, at which point it then snapped round like it wanted to kill me. And under normal driving I found I was slowing down a lot more for corners. It just didn't feel stable.Not big on the TF's feel a lil cramped when I jumped in one at the scrappy. Normal driving feels fine enough just the standard setup is a little unforgiving on speedbumps, not like cheap coilovers but not far off I'd say so lowering springs can only help with that right?
(14-08-2013, 06:48 AM)Niall Wrote: [ -> ]must say, i went up the hill with Steve (giggidy) at pugfest in this and it handled fairly well but sorry to say it, wasn't a patch of a 306. Not saying that because im bias but i was genuinely surprised at where it was loosing control considering how flat it cornered as well!Yea it was the "still not as good as a 306" comments afterwards that's made me throw my hands in the air and go "f**k it I'm beating a gti6 even if it kills me" I really think the nankangs are the weak point currently though, they weren't far off being brand new when on the hill climb (had like sub 300 miles on them)
(14-08-2013, 08:36 AM)jammapic Wrote: [ -> ]Also, the thermostat can stick closed. The engine will get hotter and hotter, destroy the headgasket but only show normal operating temp on the dash gauge. This is what my mums did!I read up on swapping them over last night and it doesn't seem like the worst job in the world to do and a replacement thermostat with seals is like £10. Will go check pipes later on and see if the pipes heat up correctly
JP
(15-08-2013, 02:20 PM)lolsteve Wrote: [ -> ]Wohooo MG defence
Just about to attempt a brake change, got my copper grease and ready to go. Also got the spring compressors for loweringgggs
(15-08-2013, 04:13 PM)Dum-Dum Wrote: [ -> ]IT might be a GTi beater but its not as fast as a stage 1 HDi so that means a stage 1 HDi must be faster than a GTi6
(15-08-2013, 04:12 PM)ginge191 Wrote: [ -> ]I notice this thread is called a "gti beater"I think the 205s weight makes it a lot harder to keep up, maybe if I start stripping out the interior too...
any chance it can go side by side with the 205?
(15-08-2013, 04:13 PM)Dum-Dum Wrote: [ -> ]IT might be a GTi beater but its not as fast as a stage 1 HDi so that means a stage 1 HDi must be faster than a GTi6It's not as fast as Poodles stage 1, which is not really just a stage 1 though. So don't be thinking your failstate could beat it haha
(15-08-2013, 04:35 PM)Norledge Wrote: [ -> ]Meh. I'd have it over a 306.
(15-08-2013, 04:41 PM)lolsteve Wrote: [ -> ](15-08-2013, 04:12 PM)ginge191 Wrote: [ -> ]I notice this thread is called a "gti beater"I think the 205s weight makes it a lot harder to keep up, maybe if I start stripping out the interior too...
(15-08-2013, 04:42 PM)ginge191 Wrote: [ -> ](15-08-2013, 04:41 PM)lolsteve Wrote: [ -> ](15-08-2013, 04:12 PM)ginge191 Wrote: [ -> ]I notice this thread is called a "gti beater"I think the 205s weight makes it a lot harder to keep up, maybe if I start stripping out the interior too...
Ok, i'll meet you half way and put my back seats back in..
(15-08-2013, 04:43 PM)Norledge Wrote: [ -> ]Don't get me wrong, I wouldn't go out of my way to buy one, but if it came to the choice between 306 ownership, MG 25 ownership and death, I'd pick MG ownership.
Very closely followed by death.
(15-08-2013, 04:46 PM)Niall Wrote: [ -> ](15-08-2013, 04:28 PM)ginge191 Wrote: [ -> ](15-08-2013, 04:13 PM)Dum-Dum Wrote: [ -> ]IT might be a GTi beater but its not as fast as a stage 1 HDi so that means a stage 1 HDi must be faster than a GTi6
you and your constant HDi ramble
Pot kettle black much!?
(15-08-2013, 08:33 AM)Dum-Dum Wrote: [ -> ]V6 HDi! best (worst) of both worlds
(15-08-2013, 08:36 AM)Dum-Dum Wrote: [ -> ]Im not voting as my opinion is HDi and or V6 so neither of the above
(13-08-2013, 04:07 PM)Dum-Dum Wrote: [ -> ]The 2.1 would do over 60mpg on the motorway on veg and at less than 90ppl the economy compared to diesel is nearly 100mpg
(15-08-2013, 05:06 PM)lolsteve Wrote: [ -> ]Just as a lil update as well, the brake changing didn't go ahead since the locating screw head twisted off and from the looks of things the same had happened when someone else had done the brakes before. Looks like I(Dad) will be drilling them out, although I've been told it's okay to not have them in since the wheel holds the disk on anyway
And the rear of the calliper is seized so need to coat it in wd40 and leave overnight, the cv boot joint thing on the passenger side it totally mullered and is being taken to a garage on Monday to have replaced since it's spat grease all over the wheel and back of the caliper
