Okay so I stripped the funked head today and when I took the whole fuel filter housing off the head the gasket broken, is there a proper gasket for it or not?
If you buy a head set you should get a new one included
I just used some gasket sealant, £3 a tube
Was fine, still is, heads been on 3 different engines since and still fine. Clean up your surfaces well, thin layer on one of them, bolt together 80% tight, then after a day or so I always nipped them to what I normally would, so then your squashing the set rubber.
