My standard td is currently boosting to 12psi. I've got an intercooler d seal on order and next week I'm going to see a 'man that can' adjust the Lucas pump and Turbo do I get more power.
What I would like to know is how far should/could I have the boost turned up to?
Carlos standard at the mo and I want more power and torque but no extra smoke and still good MPG.
Advise and pointers please.
at least 20psi and maybe a little more depending on A. how big your balls are and B. how much mechanical sympathy you have . .
Well I need it to be as reliable as possible as its an everyday car for the family!
(12-05-2013, 07:00 AM)no2lurch Wrote: [ -> ]Well I need it to be as reliable as possible as its an everyday car for the family!
well don't tune it then
. . . . i have 2 kids mate and i run 24psi been good for nearly a couple of years now but it's up to you . .
Could a leaky down pipe join cause boost leak? Visit not worth turning the boost up till the leak is sorted?
(12-05-2013, 12:07 PM)no2lurch Wrote: [ -> ]Could a leaky down pipe join cause boost leak? Visit not worth turning the boost up till the leak is sorted?
no, because downpipe is after turbo . .
Didn't know if back pressure would be effected
(12-05-2013, 12:45 PM)no2lurch Wrote: [ -> ]Didn't know if back pressure would be effected
"affected" . . .yes it will be but we don't need back pressure . .
Not after the turbo anyway
Would the Lucas pump limit the amount of boost I can tun?
Depends how much boost you want, your only getting upto like 22 or something from a lucas
(12-05-2013, 01:50 PM)Tom Wrote: [ -> ]Depends how much boost you want, your only getting upto like 22 or something from a lucas
Im pretty sure you can get alot more than that on a lucas but may be wrong
My bad thought i read it in another thread.
