14-04-2013, 11:52 AM
14-04-2013, 12:14 PM
Over 1000 is when you need to worry
14-04-2013, 12:37 PM
Aluminium melts around 650 degrees, so prolonged temps above this will probably start to damage things.
14-04-2013, 04:31 PM
700-750*C really is around the maximum safe limit as far as prolonged use goes - i.e. towing up a hill for 5 miles.
Short period 800-850*C is just about acceptable, over that you're really into unknown territory - I've seen 900-950*C before now and it's VERY easy to see that - people don't realise HOW easy it is to see those sorts of temperatures!
1000*C would be 1/4 of a turn of the fuel screw too much from 850*C...
14-04-2013, 06:17 PM
That sounds good ok cos im not hitting those excessive temps very often. Havent seen over 900 yet
14-04-2013, 06:28 PM
its amazing how much a little turn on the max fuel does to the egt's, I'm a lot more careful with my pump since having a gauge.
14-04-2013, 07:10 PM
My hdi saw 950 degrees on the nurburgring, was pushing 130mph on the main straight though, and was building to that all the way, was only at that temp for about 20 seconds.
Also worth noting that my EGT sensor is located in the manifold, before the turbo.
14-04-2013, 07:25 PM
(14-04-2013, 07:10 PM)Jonny81191 Wrote: [ -> ]My hdi saw 950 degrees on the nurburgring, was pushing 130mph on the main straight though, and was building to that all the way, was only at that temp for about 20 seconds.
And now your cars stuck in France........
14-04-2013, 07:52 PM
(14-04-2013, 07:25 PM)ozonehostile Wrote: [ -> ](14-04-2013, 07:10 PM)Jonny81191 Wrote: [ -> ]My hdi saw 950 degrees on the nurburgring, was pushing 130mph on the main straight though, and was building to that all the way, was only at that temp for about 20 seconds.
So???
EGT's didn't melt the aux belt causing it to be eaten by the cam belt.
14-04-2013, 08:07 PM
or did it
14-04-2013, 09:16 PM
Bad luck johnny ive shredded an aux belt but to get it caught up in timing is a bit misunfortunate... Still at least its not a rod!!
14-04-2013, 09:55 PM
at least youve had the most spectacular breakdown of the year johnny. im sure theres an award in there somewhere haha
25-04-2013, 05:42 AM
to be clear on e g t temps turning scre w inwards gives higher egt
is that correct
is that correct
25-04-2013, 11:05 AM
More fuel = higher EGT.
