Just want to know...
Is it possible to remove the pulley from the ac pump and just fit a shorter belt, rather than removing the pump itself? I can see the belt 'slapping' between crank and ac pulley on idle, making a terrible noise in the process
Arron
How sure are you that it's the aircon causing the belt slap, rather than the bottom pulley or tensioner?
PE02 id like to keep the pump, for now anyway, hence asking if i could just take the pulley off, makes it much easier for now too
Poodle - If you look down beside the drivers wheel at the crank pulley, which is only 2 month old you can see the belt vibrating between crank and ac pulleys.. I replaced the crank pulley with a 307 type as i thought the noise was that but its not - its got to be the ac pulley, ive ignored it for long enough as i thought id have to remove the pump and everything else but i just had an idea, remove the pulley and fit the shorter belt
I see what your trying to do. The pump will just be dead weight so is it not just as easy to remove the pump and leave just the lines in place. Then if you want it back on then refit the pump and regas? Does it even have gas in it now? Most dont.
Its probably not as easy as just removing a bolt and pulley? Or thats how im looking at it unless im missing something, hence thread.... I dont want the air con but it looks like a summers day job removing it all in one go! If i can do this for now then i can remove the pump totally later on down the line.....
I dont have my pump anymore or i would have a look. Its getting all the pipes out that took time on mine. To get the rad and pump off was fairly straight foward. But yeah if the pulley just bolts on then it would be quicker.
Just grind the pipes into bits, is it a bumper off job removing the pump/pipes? Saying that if there's any of that stuff inside the pipes it wouldn't be healthy to splatter that everywhere!
Aye thats a good idea, if anyone has a pic of AC pump pulley it would be appreciated. The rad for the ac is kinda protection against stone chips for the engine rad with the open IC.
The pipes are a pain due to the routing, had to twist and cut and snap mine out. Yeah front end off. Think we took the slam panel too just becase it gave more room and it wasnt too much after taking the bumper off anyway. And you need to make sure its empty as its illegal to just let it out.
I can get it emptied but yea, i gathered it was a 'summers day' job!
(05-04-2013, 06:26 PM)PE02KHG Wrote: [ -> ]The pipes are a pain due to the routing, had to twist and cut and snap mine out. Yeah front end off. Think we took the slam panel too just becase it gave more room and it wasnt too much after taking the bumper off anyway. And you need to make sure its empty as its illegal to just let it out.
Oops (only if you get caught)
Lol, i removed aircon units on my past 306's, so easy to do but you need to make sure you either:
- Leave the pump on and remove everything else (just use it as an Aux Pulley)
- Take all off and get a shorter belt
Rich, is the pulley on the pump removable, so i can just remove pulley>fit shorter belt?
Just mtfu and take it off! Surprising how heavy they are. Was surprised when I lifted my ac pump off the xud block
If its that easy come to do it for me boss
Haha nope
(05-04-2013, 07:22 PM)Rich306 Wrote: [ -> ] (05-04-2013, 06:26 PM)PE02KHG Wrote: [ -> ]illegal to just let it out.
Yeah mine just randomly leaked out too. Although as it was empty i didnt release anything so didnt do anything wrong.
There's nothing in the pipes to splash everywhere, apart from possibly some dye. And Dec's right, it is that easy. Four bolts and headlight connectors - that's the front end off, then another four bolts gets rid of the compressor. The rest can be done with a knife and junior hacksaw. Took me about two hours last time, it's not like you need to worry about breaking any of it haha!
(05-04-2013, 07:45 PM)Arron Wrote: [ -> ]Rich, is the pulley on the pump removable, so i can just remove pulley>fit shorter belt?
It's three or Four bolts holding the AC pump one, it'll be harder removing the pulley trust me.
Why do you have to remove the pump?
Just measure up a route that doesn't include the Air Con pump - the pump can stay there, just don't put the belt round it...
Just measure up the belt in mm and tell the motorfactors you want a "6PKxxxx" xxxx being the length in mm.
(06-04-2013, 09:26 AM)Ruan Wrote: [ -> ]Why do you have to remove the pump?
That is true, but if he's changing the belt he might as well just take the extra weight out!
Ah very true Ruan. Feel like a batty boy now. Thanks for the advice everyone. Repped
Anytime fella. Let us know how you get on.
Aye yeah, but like that, just sack off the pump anyway - makes no difference lol!
You sure it is the aircon, as i had the same on mine, the belt was vibrating between the between crank and ac pulley on idle, it turned out the manual tensioner was not tight enough and the noise was the spring loaded tensioner bouncing off it's stops.
I took the tension off the spring loaded one and re adjusted the manual one and all was good.
I think the last time i fitted a belt i didn't have the tension fully off the spring loaded one when i tensioned it with the manual one so it didn't go tight enough.
Worth a look
I have simalar problem brought a 306 hdi the air con was removed tried putting a non air con belt on and just sqealing like a pig any ideas of the belt i need or part number would be awsome I've looked everywere cheers all
I havent done anything with this yet. Titch i dont think we've touched the manual tensioner before its got a 10 month old tensioner on there now... Major if you put some chalk on the belt whilst its running, if it stops squeeling its probably your pre tensioner.
Found the reason my hdi ac didn't work today.... I checked all the pipes as they came off and all were fine. Took the ac rad out today (between fans and coolant rad) and the bottom few rows had just disintergrated lol!! So there was no gas left in my system, just some leak detect dye. If you did decide to remove it, it's only one 8mm Allen bolt to undo the pipes from the pump, and 4 bolts (without captive nuts!) to remove the pump itself. Not hard at all. Not sure if you can.remove the pulley easily due to the electric clutch in it.
I've tried this shorter belt method and it doesn't work if you're running stage 2 or higher. Not very good if you use it as your daily driver. The belt always shreds itself because of the lack of guide pulleys. The best way of doing it is running the OEM non AC belt setup, which involves a new alternator bracket and a few more pulley, but the belt sits fine even running at 170hp and not taking it easy.
Might be worth looking to see if you've got another problem fella - know a few who run this setup on a stage 2 without issue.
The non-ac oem kit is definitely worth getting if you can find it though, much better solution.
