26-02-2013, 05:35 PM
alright guys
on a little mission to get the silver beasty running better so thought i would post up for some advice.
from cold it wont start unless you use the throttle with out throttle it will sort of come to life running on the starter then die. once started there is a fair bit of wight smoke (diesel) till it is warmed up now i have hunted out 3 air leaks and sorted them and there dosen't seam to be any more and dose start a little easier but still not as it should.
had a little read up and see atopic about fuel fiter in the tank?? have fitted a new fuel filter under the bonnet asthe housing was leaking so swapped that over
cars a ph1 bosh pump m reg could try and get a video if that would help
