Right its time to upgrade my turbo as my k03 is on its way out!
Instead of replacing it with a T2 I took to mind "GO BIG OR GO HOME"
Im now looking for a TD04 and was wondering what I would need for it to bolt straight on....
Ive seen someone selling adapters so that's a start
you'll need a custom oil line making up too . . .that's it iirc . .
TD04 isn't a go big or go home turbo :-P
just scroll through the xud section, a lot of threads about it
(23-01-2013, 05:43 PM)Mattcheese31 Wrote: [ -> ]you'll need a custom oil line making up too . . .that's it iirc . .
Only problem i just found is that I have a k03 and cj is only selling t2 adaptors!
Think Ruan needs to make a looong topic on whats needed for a TD04 and pin it, or somebody as its always being asked.
I have a td04 bolt on kit with Bosch pump for £270 posted if interested, it's proven at 177bhp
(23-01-2013, 07:28 PM)Piggy1987 Wrote: [ -> ]yes but its a bit pricey
Yeah true! Was just a bit curious about the TD04 HL 13T
Ive heard TD04 HL and TD04 L is what I should be looking for...
£75's pricey?
Sorry but if someone thinks £75 for a blower is expensive they need to rethink modifying their car...
that is pricey...they go for 40-50 usually.
Its not a rare turbo and can be found on many many different cars
HL is the laggy one, turbine housing is a bit bit
Not sure saying "its the laggy one" is entirely. Although yes it is a larger hotside and will spool slightly later
Am I right in saying they are the 2 to look out for??
(23-01-2013, 08:40 PM)4WayDiablo Wrote: [ -> ]Not sure saying "its the laggy one" is entirely. Although yes it is a larger hotside and will spool slightly later
No I know, I really meant laggier one, out of the TD04 choice.
(23-01-2013, 06:09 PM)Dicky Wrote: [ -> ]Think Ruan needs to make a looong topic on whats needed for a TD04 and pin it, or somebody as its always being asked.
I disagree, i think people should just stop being lazy and read through the masses of information that is available already.
(23-01-2013, 10:50 PM)Jake Wrote: [ -> ] (23-01-2013, 06:09 PM)Dicky Wrote: [ -> ]Think Ruan needs to make a looong topic on whats needed for a TD04 and pin it, or somebody as its always being asked.
+1
even I know, and I drive a 106 ffs
(23-01-2013, 09:28 PM)Ricky Wrote: [ -> ] (23-01-2013, 08:40 PM)4WayDiablo Wrote: [ -> ]Not sure saying "its the laggy one" is entirely. Although yes it is a larger hotside and will spool slightly later
That title would belong to one of the TD04H ... Out of the TD04 choice :-P
And probably a 19t/g at that
Or why not make a hybrid TD04 like i am going tobe doing, TD04L with a 19t housing
Is everyone on here with a td04 have there wastegate welded ??
get an oil return made up by Jenkosowls mate and cj for the adapters.personally i think £75 for a turbocharger is a fair price if their is no shaft play and considering you can pay thousands for a turbo.
People need to stop being such tightarses, or do some research so they know how to find cheaper/fit cheaper ones....
As much as people try and make them 'easy' to put on like with the feeds/plates etc you still need to do abit of leg work with your car and with your research. If you know exactly what you're looking for/know how you want your setup you can get it all up and running for pennies.. but that takes research and time to wait for things to come along.... but I mean fucks sake, when your looking at sub £150 for a larger turbo fully fitted to your motor I dont know how people can complain at that... man the f*ck up, pay some cash and get it done/out the way, or spend a little longer doing some more research/possibly making your own things maybe? theres no easy way to say get XYZ and bolt those to ABC and it'll cost you £1.23. If you want bolt on stuff then you have to pay for the convenience and its cheapest its ever been.
If you think about it, a hybrid bolt on turbo for a Audi tdi etc. will cost £1000+, in comparison to spending £200 and maybe doubling stock power, it's an absolute bargain imo. Fair enough it won't be a hybrid, but there not really necessary for these.
You can get bargains though, my TD04 was £23, my GT20 was £50, and it was mint, fully cleaned etc. Need to look out for badly advertised things on Ebay.
(24-01-2013, 06:25 PM)Ricky Wrote: [ -> ]If you think about it, a hybrid bolt on turbo for a Audi tdi etc. will cost £1000+, in comparison to spending £200 and maybe doubling stock power, it's an absolute bargain imo. Fair enough it won't be a hybrid, but there not really necessary for these.
Yep agreed but the question I was asking is have most people with a td04 had the wastegate welded for it to fit??
Or atleast with cj's adaptors??
Some people have, some people havent, it makes a difference which turbo you have to how badly it will benefit/restrict you, hence do some research to understand why you should/shouldn't dewastegate.
(24-01-2013, 06:37 PM)scottbmxer Wrote: [ -> ] (24-01-2013, 06:25 PM)Ricky Wrote: [ -> ]If you think about it, a hybrid bolt on turbo for a Audi tdi etc. will cost £1000+, in comparison to spending £200 and maybe doubling stock power, it's an absolute bargain imo. Fair enough it won't be a hybrid, but there not really necessary for these.
Yeah most people do, I did. It is harder to fit the actuator down the back. I wouldn't worry too much about it over speeding and blowing it, they are pretty bulletproof. Just get an EGT gauge to keep an eye on temps.
Downside of welded gate, you need to run less fuel than if you had a gate, which will decrease power slightly. Still make good power though.
