Threads: 18
1
Car Model/Spec: 48th peugeot 205
Given 2 thank(s) in 2 post(s)
so im replacing my brake lines
Does anyone know what fittings i need for a 205 1.8d?
i think 12 M10 unions will do me?
Threads: 371
29
Car Model/Spec: ford fiesta
Im sure theyre m10 x 1.0
Threads: 18
1
for the 1.9 gti "you need 14 M10 unions and two M12, one side of the inline brake compensators has the larger thread."
from 205gtidrivers
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Given 31 thank(s) in 31 post(s)
depends on the rear brake setup
if you have drums, then you shouldn't need the m12 as the compensators are built into the rear wheel cylinders.
if you got discs though, they have inline compensators that have m12 on one end and m10 on the other.
Threads: 18
10
Car Model/Spec: 3 x 205 GTi & 306 HDi
From memory the base model drums (ie the ones with in-built compensators) don't use M10x1 fittings but something larger.
1.6 GTi spec drums (that have a separate compensator in the engine bay) are M10x1 as are all the other unions, with the exception of one side of 1.9 non-ABS compensators as mentioned.
Threads: 42
28
pretty sure as Anthony mentioned that the wheel cylinders may be M12.
also for ease of fitment I would do as peugeot did on the 306 and citroen on the zx, which is to use an inline joiner at the base of the bulkhead to link up to the pipes going off to the rear.
Threads: 371
29
Are you re doing all the lines? The m12 one is just on the rear.
