Picked this up 2 weeks ago
new mot from today
157K
It quite tidy i think for a ph1 with 2 or 3 little dents around it and some normal lacquer peal inside is clean bosh pump haven't looked to see what turbo its got fitted
all windows and central locking rear wiper etc work on it 1 key for all the locks none of the locks have been screw drivered
Drove it 8 miles to and from mot test center no nasty bangs on clonks temp gauge stayed at 80 and very slowly come up when left ticking over. back wheels sit up as they should.
bad points are when its cold its a bit of a pig coughs smokes untill you give it a rev (i don't tend to do that cold turbo's and all that) so could do with some glow plugs or has a slight air leak some were once warmed up its fine lasted taxed in December so good run might do it some good or the pump setting up? put some fresh fuel in it for mot smoke cleared so didn't worry
has a strange rip in the back seat that you can't see/notice unless your looking for it, ermmmm think thats it
£300 will give £10 to the forum if it sells on here
got the log book and mot and 1 key thats all i can say about it really
any one interested give me a pm all questions thoughts welcome need to sell need the space EDIT now needs a battery as the old ones died from it being sat
update: took it for a spinb round my privet estate today wile playing musical peugeots and the clutch dosen't slip on boost in 2nd i even tryed pulling the hand brake up building the revs up (1500~2K) and letting the clutch out slowly and it stalled so i'm guessing the clutch had some derv on it from me doing the fuel filter maybe after stalling it started up no problems so its only a bit of a pig when stone cold
