Threads: 3
Car Model/Spec: 306 XUD TD
Country:
My 1995 306 XUD TD is becoming very difficult to start. Once it starts, there is quite a lot of grey smoke from the exhaust. I've replaced the leak-off tubes (which in all fairness did need doing). The priming bulb does not appear to be holding pressure as it used to. No visible leaks under the bonnet.
Threads: 52
4
Car Model/Spec: XSi 16v
Given 83 thank(s) in 81 post(s)
Yea, from memory (reading previous posts) the fuel filter housing is worth a look at.
Btw, welcome to the club both of you!
Threads: 42
28
did you fit oem 3mm rubber pipe or cheapo aftermarket 1/8" (aka 3.2mm, i.e to big)
