egr
egr
I have a massive air leak on my dturbo checked all hoses sealed intercooler my egr is disconected but feel this is the issue can it be pushed open with pressure even though its not conected.and can i block it by cutting a metal plate and fitting between egr nd manifold. Also if i steadily build up speed its not so bad but floor  it loads of air loss of power
Not sure if ive worked out problem. When i turned the turbo i then done the max fuel screw then the compensator but ive found that i have not turned the max fuel screw just twisted the allen key so i think i have boost from the turbo but no fuel.
