Threads: 87
48
21-05-2017, 07:29 PM
i've been trying to get a good friends xsara picasso going, his wife passed away unexpectedly recently of a heart attack, he doesn't drive, car has stood for last 4 weeks, battery was flat, so i took it off and charged it, turns over well enough but will just not fire, tried a bsi reset, no joy, no lift pump on this so gave hand primer a good pump, can see fuel in the pipes, at a bit of a loss really, car is on an 07 plate so probs worth sub a grand, he's selling it but can't justify paying to get it lifted to a garage and diagnostic bills too . . . .
car was running fine prior to her passing,
any thoughts will be appreciated, cheers men x
Threads: 252
7
Guy on our road has same issue. Was ment to go round and have a look before chritsmas but not had chance
TD04 11mm Sedan, now 2.1 vnt
Sedan Project
http://306oc.co.uk/forum/thread-5763.html
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 87
48
Kyle, it's nearly June
Threads: 34
8
Given 7 thank(s) in 7 post(s)
Sometimes hand priming isnt enough they can be proper tw@ts IF the fuel has drain back or filter changed.. We use a BIG syringe in work that will suck up over a litre.. Fuel pipe back on and they go. If its only being sold try some easy start/wd40/brake cleaner/lynx body spray etc
23-05-2017, 05:27 AM
(This post was last modified: 23-05-2017, 05:29 AM by Poodle.)
Try a different battery, if that one went flat in four weeks it was on it's way out anyway and may not be putting out enough voltage for the ecu to be happy. I take it nothing else has been touched in the meantime, nobody has been fiddling in there to try and start it?
Threads: 343
15
Given 3 thank(s) in 3 post(s)
Tow start it I'd say my missis had one and after I'd done some work on it, it was the same flattened the battery twice towed it and away it went.
Threads: 132
Given 6 thank(s) in 6 post(s)
Had an obd scanner on it?
