Technical Data
wheels.pdf (Size: 34 KB / Downloads: 63)
wheel alignment.pdf (Size: 35.49 KB / Downloads: 56)
vin engine number location.pdf (Size: 46.01 KB / Downloads: 35)
Timing belt replacement interva.pdf (Size: 219.59 KB / Downloads: 78)
service reset.pdf (Size: 48.3 KB / Downloads: 39)
belt-jacking.pdf (Size: 761.12 KB / Downloads: 59)
technical data.pdf (Size: 128.2 KB / Downloads: 50)
Known Fixes
airbag-srs.pdf (Size: 11.62 KB / Downloads: 45)
body.pdf (Size: 10.91 KB / Downloads: 62)
Engine managment pin data
engine managment pin data.pdf (Size: 681.81 KB / Downloads: 62)
Engine bay Layout
enginebay layout.pdf (Size: 126.04 KB / Downloads: 55)
Engine management component testing
Control system.pdf (Size: 98.23 KB / Downloads: 34)
Emission control system.pdf (Size: 89.42 KB / Downloads: 42)
Engine sensors.pdf (Size: 166.64 KB / Downloads: 62)
fuel system.pdf (Size: 165.01 KB / Downloads: 31)
Ignition system.pdf (Size: 109.1 KB / Downloads: 41)
Intake system.pdf (Size: 150.65 KB / Downloads: 39)
service adjustments.pdf (Size: 12.83 KB / Downloads: 35)
Vehicle sensors.pdf (Size: 83.13 KB / Downloads: 32)
Fault Finding
backfiring.pdf (Size: 10.79 KB / Downloads: 24)
engine difficult start.pdf (Size: 11.18 KB / Downloads: 26)
engine non start.pdf (Size: 11.23 KB / Downloads: 28)
engine start then stops.pdf (Size: 10.83 KB / Downloads: 19)
erratic idling.pdf (Size: 11.07 KB / Downloads: 28)
excessive fuel consumption.pdf (Size: 10.98 KB / Downloads: 26)
hesitation poor acceleration.pdf (Size: 10.67 KB / Downloads: 32)
high CO level.pdf (Size: 11.01 KB / Downloads: 17)
high idle.pdf (Size: 10.66 KB / Downloads: 16)
knocking pinking.pdf (Size: 10.74 KB / Downloads: 21)
lack power high speed.pdf (Size: 10.61 KB / Downloads: 24)
lack power low speed.pdf (Size: 10.72 KB / Downloads: 21)
low CO level.pdf (Size: 10.67 KB / Downloads: 13)
low idle.pdf (Size: 10.64 KB / Downloads: 15)
misfire.pdf (Size: 10.72 KB / Downloads: 16)
overheating.pdf (Size: 10.44 KB / Downloads: 18)
poor start engine cold.pdf (Size: 10.68 KB / Downloads: 14)
running on.pdf (Size: 10.64 KB / Downloads: 19)
smell of petrol.pdf (Size: 10.45 KB / Downloads: 17)
stalling cutting out.pdf (Size: 10.68 KB / Downloads: 17)
Wiring diagrams
engine -5-97.pdf (Size: 158.75 KB / Downloads: 43)
engine +5-97.pdf (Size: 155.98 KB / Downloads: 30)
abs +97.pdf (Size: 108.31 KB / Downloads: 19)
AC fans -5-99.pdf (Size: 154.5 KB / Downloads: 30)
AC fans +6-99.pdf (Size: 156.7 KB / Downloads: 24)
earth points.pdf (Size: 38.56 KB / Downloads: 39)
fuseboard 13.pdf (Size: 133.95 KB / Downloads: 34)
fuseboard 30.pdf (Size: 162.59 KB / Downloads: 37)
Known Fixes
Engine bay Layout
Fault Finding
Wiring diagrams
GTI6 Info
