Threads: 252
7
Got a petrol strimmer it was brand new in march used it once and it was brilliant fired straight up. Drained tank and put in garage. Now it just wont start no spluttering or anything. Theres strong spark, plugs wet and can smell fumes from exhaust, and air filters clean. But it got no life whatsoever. Been at it all day fresh fuel mix ect but its really puzzling now. Never had problems with 2 strokes after long storage but we are out of ideas now.
Any help?
TD04 11mm Sedan, now 2.1 vnt
Sedan Project
http://306oc.co.uk/forum/thread-5763.html
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 371
29
Car Model/Spec: ford fiesta
24-10-2015, 07:19 PM
(This post was last modified: 24-10-2015, 07:19 PM by bashbarnard.)
Sounds stupid but have you pumped the little primer. If so leave the plug out over night let the fuel in there evaporate. Hold a lighter over the plug to clean that. Leave it till morning. Pump primer and give a go.
Ps old mans strimmer always plays up. Just takes some grunt to start after storage.
Threads: 101
Car Model/Spec: 306HDi 90 LX
24-10-2015, 08:15 PM
(This post was last modified: 24-10-2015, 08:15 PM by Magenta Sunset.)
carb gummed with fuel & oil?
my dad had a 2-stroke hedge trimmer, had the same prob. after getting it sorted was advised to drain tank, then run til carb was empty as well.
It goes, it stops (as reqd).
Hate Housework!
Threads: 25
Car Model/Spec: Vectra & Berlingo
Given 5 thank(s) in 5 post(s)
When I used have mini motos this was a regular thing. I used to drain all fuel from them, then pull start it 30-40 times so the carb is dry. Clean the plug, fresh fuel but only a little. Normally 2-3 pulls and they were started. Worked every time.
Threads: 465
114
Car Model/Spec: Vauxhall
just repaird dads strimmer
both fuel pipes in tank were perished also the carb filter was blocked so you couldnt prime the engine as the primer pump would go hard and not move fuel
carb filter was behind the primer bulb within the carb so a carb strip and clean job
Threads: 252
7
Cheers that confirms what i said to clean carb. ill give it a try its father in law it was drained after use. New plug tryd aswell. I said clean carb but he didn't want to strip it been pretty much brand new but only thing it can be
Sedan Project
Blaze 1.6 Dead
Threads: 162
21
I'll second the carb.
Two stoke oil left over time gums up the needle and diaphragms in the carb.
I always flush out the carb with WD40 after use, to flush the fuel and oil out.
Threads: 61
Car Model/Spec: Phase 1 306 xsS
Given 21 thank(s) in 21 post(s)
Don't use wd40 on your carb, it will break down your rubber gaskets over time! use specified carb cleaner to gut it out before you even pull it again!
Threads: 162
21
There isn't any rubber in our carbs.
Threads: 145
2t strimmer with a priming "bubble", the carb has a small pump ( perry pump ) which has a diaphragm usually, which is most likely made form a rubber like material.
Good spark and compression, and seems to have a wet plug ( which is clean ?? ) and engine "pumps" or breaths........
let us know how you get on. I wonder if........
Threads: 61
Your float bowl/sump will also have a rubber O-ring gasket to achieve a seal too!
Threads: 61
Cool, too used to bike carbs!
