Big Garage Clearout
Big Garage Clearout
I'm busy getting the garage in order for the summer projects, I have the following for sale!
Peugeot 405 Exhaust System
If anyone is still driving one of these bad boys, then they might have use for an exhaust. Removed from a '96 1.9 TD saloon, but I wouldn't be surprised if it fitted other models.
Nearly new, front section approx. 15k use, middle and back box approx. 3k. Has been stored down the side of my garage for a number of years so is scruffy in appearance. £25.
[Image: 405exhaust.jpg]
Peugeot 306 GTI-6 Front Callipers
Good used condition, £40.
[Image: 306callipers.jpg]
Brembo Discs for 306 GTI-6
New Brembo discs, have been stored without packaging so have some light surface rust, will scrub off with a couple of stops. £45.
[Image: 306disk1.jpg]
[Image: 306disk2.jpg]
DW10/HDI Con Rods
Set of DW10 con rods, no shells. £40.
[Image: rods6.jpg]
Peugeot 405 Steering Rack Boots
Original OE steering rack boots, part numbers 4066.30 and 406.37. £20.
[Image: steering1.jpg]
[Image: steering2.jpg]
Peugeot 405 Rear Chassis legs
A set of OE chassis legs, originally purchased for a Mk2 1.9TD saloon. However these will fit many models as the only difference seems to be the exhaust hangers which could easily be modified to suit. New parts, but do have some cosmetic damage from storage. £60.
[Image: 405_legs_1.jpg]
[Image: 405_legs_2.jpg]
[Image: 405_legs_3.jpg]
K14 Turbo from a Peugeot 405 TD
Blows a bit of oil and sounds like a police siren, only good for a rebuild. £15.
[Image: turbo.jpg]
Bosch AS3 Injection Pump
From a Peugeot 406, car was running fine up until it was removed as it's leaking from the input shaft and throttle arms seals. Has been run on 80/20 veg/misfuel blends for approximately 50k. I have a rebuild kit for it which can be added at extra cost. Not suitable as a replacement for the mechanical VP20 as found on earlier models, 306 etc. £40.
[Image: as3.jpg]
'95 Peugeot 405 GLX with XU10J4RS and ITB's
'97 Peugeot 406 1.9TD with TD04
'05 RenaultSport 182 Cup
Very interested in the discs...
Got proof they brembos?
Shazam!
[Image: 306disk3.jpg]
Discs and chassis legs sold!
Where are you based?
Near Glasgow but can post.
Rods.....SOLD!
  Garage Clearout Grant 15 2,922 15-04-2012, 09:43 PM
Last Post: devils_fuel
  Garage clearout sale 4WayDiablo 38 8,662 27-03-2012, 09:01 AM
Last Post: Grant
