Threads: 79
17
Car Model/Spec: Down and out HDi racestate
Any guides or advice etc for swapping a clutch? Any bits i might have missed? Clutch set, gear box oil, clutch cable and shaft seals. Think thats it, got axle stands and a couple of jacks and a clutch alignment tool.
Cheers all.
Threads: 110
20
Car Model/Spec: Estate, DT, GTI6 and 205
Given 30 thank(s) in 30 post(s)
An extra pair of hands is alway helpful when lining the release bearing up when putting the box back on.
Also some penetrating fluid to help get the pin out the clutch arm
Threads: 210
1
Car Model/Spec: Ph1 White Gti6/306 DTurbo
Given 7 thank(s) in 7 post(s)
Threads: 78
49
27-08-2014, 09:00 PM
(This post was last modified: 27-08-2014, 09:01 PM by Curt.)
May also want to change the fork bushes whilst you're changing everything else.
Threads: 386
87
(27-08-2014, 09:00 PM)Curt Wrote: May also want to change the fork bushes whilst you're changing everything else.
Definitely this. Makes a huge difference!
Threads: 581
195
Second this. Well worth doing. The old ones wear out and allow a bit of play in the shaft (giggidy) and can also stick slightly giving a notchy gear change. They are about £3 from Pug each.
Threads: 169
91
Given 1 thank(s) in 1 post(s)
(27-08-2014, 09:44 PM)Niall Wrote: (27-08-2014, 09:00 PM)Curt Wrote: May also want to change the fork bushes whilst you're changing everything else.
Make sure they are genuine Pug ones though.
I have had two different 'OEM quality' aftermarket versions now. They are a tiny bit too big, so pinch the fork arm giving a stiffer clutch.
Threads: 581
195
Oh and also another point with the bushes. When you remove the shaft to replace the bushes, clean the ends up with some sand paper but do not use any grease in the new bearings. They are teflon so don't need any grease or copper slip which could even cause more of an issue!
Threads: 386
87
(27-08-2014, 08:41 PM)Nathan1305 Wrote: also are these the seals I need? http://www.ebay.co.uk/itm/110998948940
Not sure of the quality of those, but a fair price if they're decent.
I've used the Bilstein ones a few times now which seem better than OE tbh.
http://www.ebay.co.uk/itm/Peugeot-106-20...5d42462bb1
Think they've got an issue with the other side one though...check the price!
http://www.ebay.co.uk/itm/Peugeot-306-20...4858e4d4a8
Threads: 210
1
I'll get some from pug should I get gearbox oil from them as well?
(27-08-2014, 09:57 PM)Toms306 Wrote: (27-08-2014, 08:41 PM)Nathan1305 Wrote: also are these the seals I need? http://www.ebay.co.uk/itm/110998948940
So all I'll need is that bilstein seal?
Threads: 164
25
Car Model/Spec: Gti6
Given 4 thank(s) in 4 post(s)
You'll need both the shaft seals and the 2 bearings, and best to get the oil from pug
Can find you the part numbers from when I did mine if you like
Threads: 581
195
Yes get genuine gearbox oil. These boxes are really picky with their oils.The genuine stuff is about £12 for 2 litres so hardly expensive.I know the 6 speed box takes 2.1 litres but its not a problem with just 2
Threads: 210
1
I'll get some from pug today
Threads: 386
87
Gear oil is 9730 AA...I know that from memory now lol!
You need two seals, both of the ones I linked, clearly they're having a stock issue with the smaller one though, hence the price lol, so you'll have to go for some others if you're doing it asap. The dealers were quite expensive for the seals though.
Threads: 127
33
Car Model/Spec: ZX Volcane TD
Given 31 thank(s) in 31 post(s)
+1 for an extra pair of hands
you can do it on your own, but it is a thousand times easier to get the box back on with some help
Threads: 164
25
Those are the pug seals for a gti, don't know what car you've got?
Threads: 110
20
As far as I'm aware all drive shaft seal are the same for all 306 gearboxes and quite a few of other peugeots like 106s and 206s and prob a few more.
I'm guessing it's for as Xud though as that's what section it's in?
Threads: 210
1
28-08-2014, 07:40 PM
(This post was last modified: 28-08-2014, 07:42 PM by Nathan1305.)
Thanks guys picking up the oil, seals and bushes tomorrow as the bushes needed ordering in so I can pick it all up tomorrow on my lunch gonna cost £51 for all that
(28-08-2014, 07:40 PM)Frosty Wrote: As far as I'm aware all drive shaft seal are the same for all 306 gearboxes and quite a few of other peugeots like 106s and 206s and prob a few more.
Yeah DTurbo XUD says below my user name
Threads: 164
25
Threads: 591
54
(27-08-2014, 08:31 PM)Frosty Wrote: An extra pair of hands is alway helpful when lining the release bearing up when putting the box back on.
Only needed for XUD boxes.
Hdi clutches are MUCH easier!!!
Threads: 79
17
Doing it on an XUD, nathans to be precise but ive only done one clutch swap before and that was when my engine was out and access was nice and easy and all seals and fluids etc were being done anyway.
Threads: 591
54
That clutch arm pin will be your nememis.
Get it soaking in sumit useful!
Threads: 210
1
Looks like we will have an eventful day then Ian
Threads: 79
17
Yeah, get here early lol. Its alright ill just get the big hammer out the shed ready.
Threads: 19
12
29-08-2014, 08:02 AM
(This post was last modified: 29-08-2014, 08:02 AM by mr_fish.)
Plenty of WD40/equvilient and a good pair of molegrips.
Failing that, bit pikey but just bend the clutch arm up just enough to get it to swing back around, then deal with on the floor.
Threads: 210
1
(29-08-2014, 07:53 AM)Slam Wagon Wrote: Yeah, get here early lol. Its alright ill just get the big hammer out the shed ready.
Yeah I think the hammer is needed
Threads: 386
87
Assuming the pin is the same as the GTi6 one, Rowell and I didn't have any issues with his one! They give you plenty to grip, not like trying to remove the pin from a HDi box to change the fork bushes!
Threads: 164
25
(29-08-2014, 08:07 AM)Toms306 Wrote: Assuming the pin is the same as the GTi6 one, Rowell and I didn't have any issues with his one! They give you plenty to grip, not like trying to remove the pin from a HDi box to change the fork bushes!
The one on mine was an absolute pig and that was with the engine out lol
Threads: 210
1
This cost £51
[attachment=18642]
Threads: 591
54
