HDI rods and shells
HDI rods and shells
Hi all, After a good set of HDI rods and shells for my build fairly sharpish. Must obviously all be straight and in one piece
cash waiting
can collect from pugfest.
I've got a spare set ...
oh wait, all straight you say ?
... nevermind
Nothing wrong with a 3 pot XUD
How many brake were you running when it bent?
Anywhere between 180ish and 240ish
So I shoild be okay ish at 200?
I would judge rods bending or escaping from the block on what power the engine is running. It's all luck of the draw even with hdi rods
Yeah, people have thrown a rod art idle with standard engines before. But hdi rods defo help. I was worrying at 160bhp on standard rods. Often revving to 5.5k revs and was fine
[Image: av5ym8.jpg]
Okay! cheers for the advice gents, Still need some rods!!
you just up your chances of not throwing a rod slightly running hdi rods, but always keep in the back of your mind that you may have one come flying out at some point
when you get fed up of changing blocks, go forged
As you did?! haha
I have a set I bought off Dave a few years ago, PM Me if interested.
Stage 2 XUD Sedan
(06-07-2014, 06:46 PM)pugmanxud Wrote: As you did?! haha
thankfully never had one escape, but was pretty close to it
At least your not running a dhy block. Im concerned everytime I get a bit carried away!
(06-07-2014, 07:05 PM)bashbarnard Wrote: At least your not running a dhy block. Im concerned everytime I get a bit carried away!
The fact your block is a dhy doesn't really make much difference. Once again its all luck of the draw. The fact is that the dhy is the most common block that these engines come with so the bigger percent of blocks that have chucked a rod prob have been a dhy but only cuz there the most common.
Well that my thoughts on it all any way
Its ok at the mo. Im not too fussed if it pops so long as its not in padstow in a few weeks
i have several sets mate if you are interested in a set still?
thanks
(06-07-2014, 05:23 PM)pugmanxud Wrote: Nothing wrong with a 3 pot XUD
i would normally agree with this.. . but after losing an injector line.. i can tell you there is a LOT wrong with a 3 pot XUD haha.. sounded good tho.
/Toseland
I bet haha!
  Wanted: Forged con rods/HDI shells,bearings Chris_90 4 1,146 11-03-2016, 10:08 PM
Last Post: Chris_90
  Hdi conrod shells Teddy 1 777 31-08-2014, 01:21 PM
Last Post: ash23
  morette outer shells and big brake kit Leemus 5 1,471 19-06-2013, 12:40 PM
Last Post: Leemus
