Threads: 2
Car Model/Spec: Td04 205 and Boosted 306
17-05-2014, 09:52 PM
(This post was last modified: 17-05-2014, 10:01 PM by Boosted-Dturbo.)
Hi, not long ago I bought myself a 1.6 205 Gti with plans to make it into a Xud track car
[attachment=16332]
[attachment=16333]I drove it about as a 1.6 Gti to use up some of the mot and tax but got bored of it fairly quickly although it was good fun.
Whilst trolling eBay and gumtree I found a cheap omp cage so got in contact with the guy and headed through to collect it.
My tip would be don't go to collect a 6 point cage in a impreza, bad idea lol.
[attachment=16334]
[attachment=16335
Threads: 92
5
Car Model/Spec: Subaru 20.d, GTi 6, 205 xs
Given 3 thank(s) in 3 post(s)
Same cage as mine im afther the front bars and door bars to
Current cars
Subaru Impreza 2.0d - Daily
Threads: 2
17-05-2014, 10:05 PM
(This post was last modified: 17-05-2014, 10:29 PM by Boosted-Dturbo.)
[attachment=16336]I didn't pay anything near the asking price for it and sold the absolutely perfect interior out it
[attachment=16337]Then got these. Mega lightweight which is the direction I'm heading
[attachment=16338]Next I got the old engine out as I sold it.
Just in time as I got 4 points for speeding in it that week.
Iv had a clean license since my teens lol.
[attachment=16339]I found a good engine from a written off 306.
Unfortunately it had a lucas pump but atleast it had a good t2 on it for my 306 workhorse which currently runs a kkk. I had a td04 lying about but it's less than ideal for many reasons but I'm happy to use it until it goes then It'l be plug and play with a td04l.
I got an td04 adapter plate and the turbo is clocked.
[attachment=16340]I got a xantia inlet and got to work on it.
I work for a company that restored classic cars so have access to handy machines
[attachment=16341]
[attachment=16342]
[attachment=16343]
[attachment=16344]Engine going in
[attachment=16345]One of many strength plates
[attachment=16346]I shot blasted most of the bay while the engine was out, acid etch primed it then it was coated with 3m spray sealant before getting sprayed. It looks a funny colour under the infrared lamp. I have plans for the upper inner arches so iv just painted enough so that the engine could go in
Threads: 2
17-05-2014, 10:37 PM
(This post was last modified: 17-05-2014, 11:07 PM by Boosted-Dturbo.)
[attachment=16347]When I was running it back and forward to work it handled like a dog despite having a gmax on the front with bilstein shocks on the rear. We stuck gauges on it and found it had positive camber on the osf and negative on the nsf so I bought camber plates to correct it
[attachment=16348]I managed to get a set of compomotives which ill have to drop off to the powdercoaters soon. I'm not keen on black wheels plus they need a freshen up
[attachment=16349]When I first fitted the engine and connected the gear linkages I found a internal problem with the gear box which had come on the engine from the written off 306 so got a spare 1.6 gti box and fitted new clutch arm bushes etc. Iv used them on the xud's before and it's a crazy ratio but should be fine for knockhill. Also it's now a push clutch instead of the heavy pull type. I took a dw8 flywheel into Engine Resource and got it lightened then buttoned everything up
[attachment=16351]
[attachment=16352]
[attachment=16353]I found I had a clearance issue with a the gear linkage and turbo. I couldn't find anything online regrading anyone with the same issue so want sure if it was to do with the dodgy variant of td04 I'm using?
I ended up modifying everything for the greater good lol.
The linkages are now fully rose jointed start to finish with bronze bushes on my DIY quickshift and gear stick . The gear feel very positive to say the least and they now clear the turbo
[attachment=16354]
[attachment=16355]
[attachment=16356]The linkages are all fitted and setup but I'll need to take pics.
I got a 205 derv loom from the scrappys and stated to sort it out with amalgamating tape and p-clip in.
[attachment=16357]I'm planning on making my own screamer pipe soon. Not exactly the normal setup but should sound good.
I'm going to make a divorced downpipe and use the wastegate side as the screamer pipe
[attachment=16358]
[attachment=16359]Can anyone tell me anything about this turbo? If it's really bad, I'll just get another to replace it. Iv had it lying about for years.
Threads: 2
17-05-2014, 11:18 PM
(This post was last modified: 17-05-2014, 11:23 PM by Boosted-Dturbo.)
[attachment=16360]I bought a stainless td04 downpipe and cut it close to the flange as it needs to instantly turn into a 90 bend.
I ordered a tight 90 today which I'll weld onto the modified downpipe flange
(17-05-2014, 10:04 PM)td_dan Wrote: Same cage as mine im afther the front bars and door bars to
Hi Dan, if I ever add sections into my cage I'll just get the joining hardware off eBay and get the correct seamless pipe from a blacksmith. The door bars would be easy to do. I'm looking for a good non sunroof roof to fit and once that's done I'm adding another roof cross in
Threads: 10
nice 205, brings back memories of my 1.6.
Threads: 2
(18-05-2014, 08:36 AM)juz22 Wrote: nice 205, brings back memories of my 1.6.
That looks a clean one. Mines has it's faults lol
Threads: 226
24
Car Model/Spec: A3 TDi
Looks like your doing a great job! Good project
Threads: 2
(18-05-2014, 01:02 PM)Tom Wrote: Looks like your doing a great job! Good project
Hi Tom, I followed the Build of your 205 and seen it on eBay. Can't believe it's not sold yet. I know how much cash mines stands me so far and that makes your a bargain
Threads: 28
3
Given 1 thank(s) in 1 post(s)
18-05-2014, 03:22 PM
(This post was last modified: 18-05-2014, 03:23 PM by ally406.)
I'm a regular at Knockhill, I look forward to seeing this going round Where abouts are you?
'95 Peugeot 405 GLX with XU10J4RS and ITB's
'97 Peugeot 406 1.9TD with TD04
'05 RenaultSport 182 Cup
Threads: 2
(18-05-2014, 03:22 PM)ally406 Wrote: I'm a regular at Knockhill, I look forward to seeing this going round Where abouts are you?
Excellent, what will you be running? I'm located in Brechin.
My friends and I have been building track cars to use this year plus one of them is doing the xr2 challenge at the moment. I can't wait
Threads: 28
3
Orange Clio 182, I was hoping to get it into SLS this year but mortgage, bills, paying for food etc got in the way. Will come over and have a chat if I see you there.
Threads: 2
18-10-2014, 04:46 PM
(This post was last modified: 18-10-2014, 04:59 PM by Boosted-Dturbo.)
Hi, been a whole since I posted with any actual progress.
I bought a couple of subaru Justys and iv been out having crazy off road fun for atleast a couple of months so the 205 has sat in my driveway lol.
[/php][/quote]
The last pic shows the 205 with a new complete front panel. It's been spray sealed so it lasts as long as possible.
I made up a downpipe which bolts onto the td04 and heat wrapped it.
Threads: 581
195
Given 81 thank(s) in 77 post(s)
Hi mate,
Project looks fantastic. Ive moved it to the correct section for you
Threads: 2
18-10-2014, 05:06 PM
(This post was last modified: 18-10-2014, 05:17 PM by Boosted-Dturbo.)
I got some silicone pipe and a alloy header tank. The plan is to get a coolant swirl pot, the largest alloy radiator I can fit in, Evans waterless coolant and a few other bits. I have to small radiators off a motocross bike which I am fitting behind the bumper with ducts. One of them is for cooling the turbo and the other is for a outlet on the cylinder head which would normally be for the heater matrix.
Today I bought Brembo four pot calipers with new discs and caliper rebuild kits. Also I bought another td04 turbo as the one I used which I had lying about is a pain for running boost pipes.
I week or so ago I got a Nitrous oxide kit which was originally a wet kit but obviously I needed dry so just removed the fuel solenoid and iv ordered a dry nozzle. I'm not too sure what jets to order, think I'll buy a load and work my way up incrementally.
The way it sits, it will fire up off the key and drive.
I fitted a good condition replacement derv loom. The fuel lines now run through the bulkhead and inside to a alloy fuel tank.
Threads: 164
25
Car Model/Spec: Gti6
Given 4 thank(s) in 4 post(s)
Looks like a great project will have to keep an eye on it
Threads: 136
11
Are you getting new wheels to accommodate those brakes?
Won't fit under 1.9 wheels
Threads: 2
(19-10-2014, 06:31 AM)Paul_13 Wrote: Are you getting new wheels to accommodate those brakes?
Hi, yeah I got a set of 16" Compomotives but I'll need to drop them off to get powdercoated soon. Not too sure what colour to go for tho
Threads: 2
24-10-2014, 04:47 PM
(This post was last modified: 24-10-2014, 05:07 PM by Boosted-Dturbo.)
I got the Compomotives sent away to the powder coater earlier in the week and hopefully get them back tomorrow. I ended up getting them done golf as I liked the look of it when I bought it so we'll see what it looks like soon.
I got my turbo, brembo 4 pots, and intercooler delivered so I'll get started tomorrow morning.
Iv ordered a alloy radiator 650mm wide with a massive 56mm core.
When I checked up on Evans waterless coolant I found the price pretty crazy!
They also want you to flush your old coolant system with their own stuff which costs about the same as the coolant.
Threads: 2
13-06-2015, 08:39 PM
(This post was last modified: 13-06-2015, 08:49 PM by Boosted-Dturbo.)
After moving house etc I finally got back to working on the 205.
I mot'd and taxed it today then maxed out the Lucas pump.
It's pretty dam impressive for not having a built Bosch pump.
I'll have to fit the Polycarb window kit and coilovers.
I went to fit the brembo's but Iv either got the wrong discs or hubs, I'll have to look into it.
[attachment=23784][attachment=23784][attachment=23784][attachment=23784][attachment=23784][attachment=23784]
