Threads: 11
Car Model/Spec: 306 1.9D
26-03-2014, 01:58 PM
(This post was last modified: 26-03-2014, 02:22 PM by jamesgmg.)
Had the battery light come on on my 306 1.9D and measured the alternator output direct from the alternator terminals and also measuring off battery terminals, getting 11.3v at idle.
Figured bad alternator so just replaced it with a new one. However the new one is giving the same results.
I've checked the big fuses in the box under the bonnet on the wing, I've checked the continuity of the + cable from alternator to battery and the earth from battery to gearbox.
I've now also just replaced the battery as the old one was 8 years old, and now getting 11.88v off the battery and back of the alternator on idle and 12.20v with some revs. So still low...
Any ideas?
Just to update this:
The battery light on the dash doesn't come on with the ignition, only when I've driven the car up the road does it come on. Wondering about the exciter wire, though don't fully understand this yet.
Can someone confirm if on the 1.9D, the battery light should come on with the ignition and then go out on start?
Threads: 581
195
Given 81 thank(s) in 77 post(s)
And what state is the car in when your checking it? Warm/cold? Take it for a drive, get it right up to temp and see what voltage you get then.
Threads: 581
195
The car has only just been started and starter motors draw a considerable amount of current. The battery needs to recharged so will "sap" power from the alternator. If that battery was fully recharged after a long drive like i suggested, it should hit around the 14.4 mark.
Take into account things like heated windows and heaters when its cold at first start in the morning as well and you have a considerable drain on the alternator as well. In the middle of winter, seeing 11v isn't unusual until its warmed up and fully recharged.
Threads: 41
3
Car Model/Spec: 306xrdt ph1
Given 4 thank(s) in 4 post(s)
Stick a wire from the batt (or alternator output wire!) +ve to the exciter terminal on the alternator via a small bulb. Say a 5w indicator one.
Bulb is to limit the current. Should excite it and check with your DVM.
You can't leave it like that tho or it will be on constant.
Then the fault is between the exciter wire and the dash.
Threads: 11
26-03-2014, 05:49 PM
(This post was last modified: 26-03-2014, 05:50 PM by jamesgmg.)
Just checked fuse F28 15 amp - battery light, clock and outside temp display, electric front windows, rear wiper and it had blown! Put in new fuse, blew that too.
So I guess I need to track down what is causing that to blow! Will check the rear wiper relay first as had problems with that last year.
Threads: 581
195
So that means your battery light will be working fine but you will still get the low voltage when its cold which is correct
Threads: 226
24
Car Model/Spec: A3 TDi
Needs the battery to tickle its balls before it puts out...
