Threads: 465
114
Car Model/Spec: Vauxhall
want to remove the O/side drive shaft to replace the rear engine mount for a vibratec bushed mount
how much oil am i going to loose from the GTI6's gearbox ?
i plan on replacing the diff seal too
if i jack it up one sided will i get away without loosing any?
Threads: 92
5
Car Model/Spec: Subaru 20.d, GTi 6, 205 xs
Given 3 thank(s) in 3 post(s)
Yes jack it up 1 side and very little will be lost iv done it a few times
Current cars
Subaru Impreza 2.0d - Daily
Threads: 591
54
Needs to be jacked up quite high...
Why not just drain ans refill?
Threads: 465
114
cause its got new oil in it from when the clutch was done
may just catch what comes out and put it back in the top
Threads: 1
The drain stud is on the bottom so just drain it out and refill it back in the breather on top when you have the shaft back in.
