Threads: 12
Car Model/Spec: 306 HDi
Hey everyone, I have a Peugeot 2.0 HDi 306, and I have got a shift light with a positive, negative and signal (green) wire. It says in the manual connect to the negative side of the coil pack. I was wondering could I attach this to the plug in behind my clocks? Does anyone have any idea how these wire in?
Can someone please help me on this? can you show me where I should put the green wire?
Thanks everyone
When the torque dips, change gear like a boss...
Will save a lot of wiring hassle and prove you dont need a fastNfurious light to know when to change gear
Threads: 465
114
Car Model/Spec: Vauxhall
Given 97 thank(s) in 92 post(s)
deleted info as it was wrong
and as you can probably guess a HDI don't have coil packs
rpm signal comes from the ecu to the dash wire number 426
Threads: 18
10
There's a fair chance that if the shift light has the required filtering to allow it to work with the signal from the back of the coil that it potentially won't work with the tacho driver output on the HDi's ECU anyway.
