Threads: 36
Car Model/Spec: PH2 Dturbo
Having a bit of bother with the car radio, the FM/AM doesn't work at all now, used to work a bit, but now it doesn't.
I have put a new aerial wire in (both bits) but doesn't seem to have made any difference,
anything i should know about? or is the general 306 aerial just plain wank?
Threads: 5
Car Model/Spec: 306
I have an in car Arial fitted on the front window I am Shure it is a Halfords one only cost £4 works relay well
06-10-2013, 05:57 AM
(This post was last modified: 06-10-2013, 05:58 AM by Poodle.)
Standard aerial has always been more than adequate for me, brand new genuine ones are only ~£15 if you fancy trying that next. Don't suppose it could be getting interference from anything, break in the sheathing etc..?
Threads: 164
25
Car Model/Spec: Gti6
Given 4 thank(s) in 4 post(s)
Iirc the aerials are supposed to be powered from the standard HU for better reception
Remember seeing a guide for adding a regulator on here somewhere but can't remember who's it was
Threads: 162
21
If you're using an aftermarket headunit get the longer aerial from a ph1 and you'll get your stations back.
Even with the reg mod the ph3 isn't that good, the ph1 aerial picks up better a lot better reception.
Threads: 178
28
Car Model/Spec: HDi!
Ah cool. I'll do this monday
