Threads: 35
Where does everybody put there power cable for the sub/amp coming off the battery.
I know there's one on the drivers side above the master cylinder but my cable isn't long enough to reach to drivers side then back to passenger side to the sub.
Is there a grommet on the passenger side in the firewall?
NO SMOKE NO POKE
Threads: 374
38
Car Model/Spec: GTI 6
Drill a hole from footwell to bay. Jobbodged
Threads: 374
38
Yeh if you want; power cables tend to be fairly large, and fill the hole quite nicely.
Given 81 thank(s) in 77 post(s)
Under the car and up through the boot vent. Job done.
Threads: 226
24
Car Model/Spec: A3 TDi
Or run power down drivers side and signal down passenger side?
Threads: 226
24
That must be a short ass cable then! All wiring kits i've used have always made it to the boot of the 306 with plenty left at the other end. Have you cut some off it for any reason or did it come like that? I always thought they were mostly the same lengths :/
