Td04 opinions - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Td04 opinions (/showthread.php?tid=9572) |
Td04 opinions - johnnytsa - 07-01-2013 Right guys need opinions on this. ive researched it but i want to know what use have done and what the outcome has been! im preparing to put a td04 on but what in your opinions is the best manifold to use? has anyone noticed significant problems using the smaller k03 manifold? also is the a big issue trying to fit it with the T2 manifold? very grateful for any help. and i have looked through project threads but just want an overall view on it! Thanks =D RE: Td04 opinions - Ben - 07-01-2013 You wont get significant problems by using the gt15/ko3 manifold, but you will obviously get a better flow if you use a t2/k14 manifold. I wouldn't have thought you would notice the flow difference, so I wouldn't worry about that too much. As for fitting it is easier to keep the actuator with the gt15/ko3 mani and also less bulkhead smashing is required. RE: Td04 opinions - martyn92 - 07-01-2013 You can use either manifold, im going to be using the k03/gt15 manifold as it looks easier plus i have 1 spare. though im thinking of enlarging the manifold exit as its tiny, not sure if it will make it better but cant see it making it worse Re: Td04 opinions - Dan! - 07-01-2013 If you feel inside the mani exit port on a gt15 there is a fairly large lip on one side which is easy enough to grind down with a dremel. |
