The Racetractor. The End. - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Photos and Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=20) +--- Forum: 306 Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=3) +--- Thread: The Racetractor. The End. (/showthread.php?tid=8415) Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
2.1GTd...RR bhp bets?? - zx_volcane - 19-10-2014 Great results! That torque! Dyno doesn't load the car anywhere the same as being on the road which sends the controller for the vnt off in this application. I've had very similar issues on dyno tbh. Be different if it was a waste gate turbo, or vnt on a boost can. Very impressive in any case, especially if you can hold that torque higher up the revs RE: 2.1GTd...RR bhp bets?? - Piggy - 19-10-2014 Not sure it would hold all that torque up top but it doesnt stop pulling on the road till 4600ish Niall: there was a LOT of different cars ran on that dyno, lots of standard from different makes/engines, Im pretty confident on the accuracy tbh Video is coming as is dyno sheet...... [attachment=19673] Im also dead chuffed with only a 12bhp loss in transmission. The saxon guys were well impressed! Does show GTB ability. Sod off TD04s!!! RE: 2.1GTd...RR bhp bets?? - Niall - 19-10-2014 Oh that graph isn't anywhere near as bad as i was expecting lol. Id be happy with that! RE: 2.1GTd...RR bhp bets?? - jammapic - 19-10-2014 That is good power to be fair, looks like it needs a wedge more fuel in it though, or the gov shimming stiffer as it looks like the torque falls away pretty quickly after its fully spooled up. Hence the low rpm the peak power is made. Fair play though, great result and great spread of power!! RE: 2.1GTd...RR bhp bets?? - akuma406 - 19-10-2014 CONGRATULATIONS my Piggy !!!!!!!!!! In a first test, I was expecting something softer lol I hope your help when I touch my arduino tune lol The second cylinder head and got, had a crack in a hydraulic tappet. . . Garbage too. . . waiting for a third. . . I also hope the dyno video jajajaj RE: 2.1GTd...RR bhp bets?? - Piggy - 19-10-2014 Wait to see the video james, you see the boost drops off for some reason around 3k rpm and fuel isnt an issue!! On the road if anything it pulls harder past that point and doesnt smoke at ALL! RE: 2.1GTd...RR bhp bets?? - Ruan - 19-10-2014 It doesn't LOOK to be a fuel issue, it's the typical controller issue, as Tom said, he's had the same problems, just the dyno load ballsing it up.... Hopefully get that sorted and another dyno run in, see what it makes then. RE: 2.1GTd...RR bhp bets?? - jammapic - 19-10-2014 Ah right. Fair point. I guess its hard to tell from the plot what disappears, fuel or air. I'll take your word for it :p RE: 2.1GTd...RR bhp bets?? - Piggy - 19-10-2014 First video of the failed run... Fyi, it made 206 at the wheels...so could be more at the fly anyway!! The proper run: Effectively double stock power anyway 2.1GTd...218bhp/351ft lbs - zx_volcane - 19-10-2014 Looks like a pretty typical xud torque curve to me? They often seem to peak and drop off like that, it certainly didn't nose dive RE: 2.1GTd...218bhp/351ft lbs - akuma406 - 19-10-2014 Piggy is seen as a cut shot or backfire at high rpm? RE: 2.1GTd...218bhp/351ft lbs - eskimogod - 19-10-2014 awesome power that and pretty nice graph too! makes me want to 2.1 mine more and back in a 306 was ment to be a cheap run around.. RE: 2.1GTd...218bhp/351ft lbs - Piggy - 20-10-2014 (19-10-2014, 09:52 PM)zx_volcane Wrote: Looks like a pretty typical xud torque curve to me? They often seem to peak and drop off like that, it certainly didn't nose dive It doesnt dive at all on the road fella. And certainly doesnt chuff like a train at 3250rpm-4250rpm it just keeps pulling clean. I wish I had sat in the car now and watched the gauges I wonder if it peaked above 1.6bar and the controller tried to bring it back and it didnt work so well!? RE: 2.1GTd...218bhp/351ft lbs - silverzx - 20-10-2014 Good 'ol figure that is.. RE: 2.1GTd...218bhp/351ft lbs - dashmader - 20-10-2014 CONGRATULATIONS Mr. Piggy, very nice power... RE: 2.1GTd...218bhp/351ft lbs - Piggy - 20-10-2014 [attachment=19676] [attachment=19677] Gave her a very worthy clean! She very much deserved it! [attachment=19678] RE: 2.1GTd...218bhp/351ft lbs - Ruan - 20-10-2014 Just LOL at the FET chilling out in the engine bay... Xtreme air cooling y0h! RE: 2.1GTd...218bhp/351ft lbs - 7057sam - 20-10-2014 Looks and sounds absolutely epic Any plans to get it out on track? RE: 2.1GTd...218bhp/351ft lbs - Piggy - 20-10-2014 (20-10-2014, 05:39 PM)Ruan Wrote: Just LOL at the FET chilling out in the engine bay... Xtreme air cooling y0h! Yeah!! Guna get a little breather for the N75 and a tiny little cold air feed for the FET, just for giggles! Haha Ooo, can you spin the last pic for me ruan?...not sure again why its done that!? (20-10-2014, 05:46 PM)7057sam Wrote: Looks and sounds absolutely epic Next year for sure I think. This winter the summer wheels will be swapped for winter ones so will be shod with something designed just for the better months and that will handle some track action. Hope to get top strut brace on too. And got some better pads in the pipeline from Anton for track time too. Also it will get an oil cooler and a proper cold air feed and some pipe tidying etc. Then its time to push it hard out on some A roads and B roads for extended periods time to see how she copes (19-10-2014, 10:03 PM)akuma406 Wrote: Piggy is seen as a cut shot or backfire at high rpm? Its odd isnt it, does sound like a misfire on the dyno, i thought something had gone badly wrong actually!! I was like, 'awww crap, that wasnt good' and the bloke was like, 'flipping ek thats got some umph'! RE: 2.1GTd...218bhp/351ft lbs - Toms306 - 20-10-2014 (18-10-2014, 09:24 PM)Piggy Wrote: Theres no section for that change annoyingly, I had the same thought though! Aw that's a shame! Decent result on the rollers tbh, looking smart as well! RE: 2.1GTd...218bhp/351ft lbs - Ben - 21-10-2014 Its been good watching this progress, you certainly have a 306 to be proud of RE: 2.1GTd...218bhp/351ft lbs - Piggy - 21-10-2014 Time for ARPs. Head doesnt like being held down RE: 2.1GTd...218bhp/351ft lbs - 1616six - 21-10-2014 I love this car James, I really do. I just can't help but feel you have shit taste in wheels, the 206 wheels you have now just look like disabled cyclones, those white Picasso wheels were even worse. Have you considered something like 206 Scirocco wheels? I love the anthracite but I just think it'd look so much better on different hooves. Good work though, I love it. RE: 2.1GTd...218bhp/351ft lbs - Niall - 21-10-2014 (21-10-2014, 10:22 PM)JJ0063 Wrote: just look like disabled cyclones RE: 2.1GTd...218bhp/351ft lbs - Piggy - 21-10-2014 I love em. Sorry! I think they really suit it!! Thanks for the other compliment though! And its cossack grey, get it right Oh and the picasso wheels will be back on next month!! Winter tyres/wheels!! Just googled those scirrococcooco wheels....yeauch!!! RE: 2.1GTd...218bhp/351ft lbs - Mattcheese31 - 21-10-2014 It's whatever you prefer wheel wise, I don't understand why you'd have those over normal clones and mess about with spacers for the privilege of a worse looking wheel but, that's just my opinion, if u like them crack on RE: 2.1GTd...218bhp/351ft lbs - Poodle - 22-10-2014 Those scirocco wheels are awful, don't put those on lol. I really like your choice of wheels so far, generally understated and different, but still manage to keep to stuff that suits the lines of the car and looks interesting. Cracking result on the dyno there, all the hard work you put in to getting the engine right paid off in the end. RE: 2.1GTd...218bhp/351ft lbs - Ruan - 22-10-2014 I'll admit, I'm not the biggest fan of the "Disabled cyclone" - but 206 Sciroccos?! Are you shitting me? They look like "Shit Harrier Ripoffs"!!! RE: 2.1GTd...218bhp/351ft lbs - jammapic - 22-10-2014 Disabled cyclone. Brilliant. RE: 2.1GTd...218bhp/351ft lbs - Mattcheese31 - 22-10-2014 (22-10-2014, 09:32 AM)Ruan Wrote: I'll admit, I'm not the biggest fan of the "Disabled cyclone" - but 206 Sciroccos?! Are you shitting me? They look like "Shit Harrier Ripoffs"!!! Yep agreed, they are worse than harriers fo sho lol |
