Oil temp - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Oil temp (/showthread.php?tid=7884) |
Oil temp - David - 11-11-2012 So today I fitted my oil temp gauge and what not and it works like a dream The question I want to ask is, what oil temp should I start to worry at? I've had it at 100 oc tonight and weren't really worried but would just like to know. RE: Oil temp - Ruan - 11-11-2012 100*C is reasonably normal, you should be seeing just over 100*C at times as it will be boiling off any condensation from the oil... Normal running temperature is about 85-90*C, but remember that DTs don't like high oil temperature, just as much as they shouldn't run too cool.... RE: Oil temp - Dave - 11-11-2012 Mine can be anything from 70-95 depending on weather/rage Need to sort my coolant stat which has a big effect on it though! |
