Where can I get a cheap cambelt kit. - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: Where can I get a cheap cambelt kit. (/showthread.php?tid=700) |
Where can I get a cheap cambelt kit. - Matt - 01-01-2012 There is one on ecp for £75 It's a conti setup but unsure if it includes waterpump Anyone got any links to a decent deal? Re: Where can I get a cheap cambelt kit. - Niall - 01-01-2012 Normally they don't include water pumps. I thought you bought that belt that I sent you the link to? Re: Where can I get a cheap cambelt kit. - Niall - 01-01-2012 Just looked on service box and a kit on there is 105 quid. They don't sell the tensioners separately unfortunately. Pump and gasket comes to 80 quid from peugeot Re: Where can I get a cheap cambelt kit. - Flynn - 01-01-2012 That Contitech one is well worth it I've always used their belts, top quality every time. Well I've only used two of them but they are definitely worth it, don't risk buying cheap rubbish. Re: Where can I get a cheap cambelt kit. - Foxy-jim - 01-01-2012 Don't buy cheap! Re: Where can I get a cheap cambelt kit. - Ruan - 01-01-2012 Gates or Contitech only for me Gates belts will put up with some serious abuse - I've seen it myself! Re: Where can I get a cheap cambelt kit. - Dan - 01-01-2012 ive fitted a fair few cambelts and the only ones ive ever had problems with are unipart ones ive had a few sheer the teeth off after a few months Where can I get a cheap cambelt kit. - Matt - 01-01-2012 Niall I got that belt, need a water pump and tensioner but can't find tensioners separate, might have to but the conti one and then a separate water pump Re: Where can I get a cheap cambelt kit. - td_dan - 01-01-2012 i got tensioner ion garage brand new if needed
Re: Where can I get a cheap cambelt kit. - td_dan - 01-01-2012 sorry mate just realised yours it petrol my tensioner is xud sorry
Re: Where can I get a cheap cambelt kit. - Scott - 02-01-2012 I don't think it'd be worth skimping on a cambelt kit mate, unless you're hoping it snaps and you can just stick a 6 engine in ![]() Will this be getting fitted at Curt's? Give me a shout if so as I'll come down for the day and help out
Where can I get a cheap cambelt kit. - Matt - 02-01-2012 I've got a Peugeot own cambelt just need a tensioner and water pump, but can't find a tensioner on its own so going to have but a kit then use that tensioner and use my pug cambelt Re: Where can I get a cheap cambelt kit. - stevieg - 02-01-2012 as far as water pumps go make sure you get one with a metal impeller as the plastic ones tend to bugger up sometimes |
