performance hdi clutch - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: performance hdi clutch (/showthread.php?tid=6612) |
performance hdi clutch - Will_306_hdi - 01-10-2012 If im correct i need an uprated clutch to cope with a stage 2 Tune. Had tax rebate so ive ordered fmic and bmc cda filter i have straight through and disabled egr. Once fitted i will have stage 2 map. Can someone recommend a performance clitch RE: performance hdi clutch - Poodle - 01-10-2012 Helix and Sachs both come highly rated, i understand Sachs do an uprated one for the berlingo that, so far, seems to hold the torque just fine. RE: performance hdi clutch - strictly_perv - 01-10-2012 CG 306 XUD Paddle clutch, will fit a HDI with a few bits being swapped over. I'm running one on my car and it's doing the job lovely and only cost £220 RE: performance hdi clutch - Midnightclub - 01-10-2012 Poodle, whats the price for the berlingo one do you know? I've heard a lot of forum talk about it but never any prices? RE: performance hdi clutch - Poodle - 02-10-2012 Not much different to the 306 afaik. If you're going to go CG, be wary of buying the ones made for the HDi, there's been a lot of bad experiences with the quality of their products. RE: performance hdi clutch - DaveW - 02-10-2012 Would'nt of botherd with the cda, spend more money on a good clutch and dont buy anything off ebay! RE: performance hdi clutch - Midnightclub - 02-10-2012 AFAIK that was only on the sprung paddle clutches mate as they go coil bound past 270 lb/ft and snap the springs! RE: performance hdi clutch - Poodle - 02-10-2012 Indeed, it was more the quality/construction issues that worried me. Fitting the friction plate backwards is a pretty major fail, as was the friction material falling off the plates after 500 miles lol. RE: performance hdi clutch - Midnightclub - 02-10-2012 Ok.. that may not've been what i was thinking of True, at least sachs is a proven brand.
RE: performance hdi clutch - Chris_90 - 02-10-2012 ive just been on the phone to helix and for a clutch to hold 270ft lb's of toque looking for nearly £400!! either there having my pants down or thats the price i should be looking at, think i will be going for limited toque to save a lot of money.... i was only looking to spend £200 is that an unreal figure? RE: performance hdi clutch - Dum-Dum - 02-10-2012 Go for the Helix or Sachs IMO mate. Yes theyer alot but if you buy cheap youll buy twice. CG are a bunch of cowboys that consider snapping springs normal wear and tear and the fact that a clutch overstrokes perfectly acceptable. Also dont believe anyone who tells you that swapping to an XUD set up with a new Valeo will hold the power of a stage 2 cos it wont RE: performance hdi clutch - Poodle - 02-10-2012 What he said lol, good clutches are expensive unfortunately. |
