Valve Clearences - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Valve Clearences (/showthread.php?tid=6458) |
Valve Clearences - Bananalad - 24-09-2012 Basically my valves are too tight causing a drop in compression.. Did a compression test and the results are as follows.. 35, 26, 25, 22 Would it be worth setting the valves clearances by getting the pieces shimmed or will the problem just reoccur in future? Thanks for any help
RE: Valve Clearences - Bananalad - 25-09-2012 Bump.. |
