limited boost out of t25 - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: limited boost out of t25 (/showthread.php?tid=5903) |
limited boost out of t25 - zx_volcane - 30-08-2012 as per title peaking at 20psi been on the hunt for boost leaks, can't see any, everything is tight, soapy watered ..etc Only thing i've done is pull the turbo and remount since the hotside clamp lost a bolt and was starting to make a bid for freedom. Also fitted egt sender Turbo looked ok Didn't replace the manifold gasket (steel), but had only been on the car about 200 miles - although can't see any obvious blowing and everything is nipped up tight. MBC is wound right in. Soooooo I'm sure it was running over 20 before all this. Turbo knackered / manifold gasket leaking / egt prob somehow causing a restriction Any ideas, as I'm fed up of going under the bonnet ![]() *edit Its probably the gasket isn't it :/ RE: limited boost out of t25 - Jenkosowls - 30-08-2012 Itl be a gasket or still a leak some where. Does it hold boost fine? Or does it fluctuate quick thing to do to make sure actuator ain't to blame is to cable tie the wastegate if it boosts over then the actuator is faulty. RE: limited boost out of t25 - 4WayDiablo - 30-08-2012 Could be wastegate creep or similar if you have ruled out leaks RE: limited boost out of t25 - zx_volcane - 30-08-2012 Holds a steady 20 psi Actuator seems nice and stiff If I over fuel it I can squeeze one or two extra psi - so don't think its wastegate creep Will change the gasket next week and see whats up - getting pretty pro at yanking out turbos these days with all this practise RE: limited boost out of t25 - con67 - 06-09-2012 When this happened to me the ball was pitted in the mbc have you tried without the mbc? RE: limited boost out of t25 - zx_volcane - 06-09-2012 (06-09-2012, 06:59 AM)con67 Wrote: When this happened to me the ball was pitted in the mbc have you tried without the mbc? worth a shot isn't it? RE: limited boost out of t25 - Dave - 06-09-2012 My MBC gave me no end of trouble on my turbo, until I realise that was cause of issue. Your situation here is very similar to another one I know, and were still baffled by it, replaced turbo/checked all intake pipes/exhaust etc still only boosting just over 20psi. I know this dosent help though lol RE: limited boost out of t25 - zx_volcane - 06-09-2012 Unplugged the mbc - still no joy Have amassed 4 different turbos that are lying around now, so will prob just get another one instead and replace the gasket at the same time. I'm kinda convinced its the gasket now as you can see on the new steel one that they have a raised outline that presumably crushes to fill in any imperfections for a one shot use. Soon as I get a day off I'll sort it. RE: limited boost out of t25 - silverzx - 06-09-2012 I hope that isnt the case as they cost a 5'er a go! RE: limited boost out of t25 - RadiationBeta - 10-09-2012 I have recently had my turbo off and used the same steel gasket and its fine. Can your turbo suck in enough air to make the boost? What is your intake piping like? RE: limited boost out of t25 - zx_volcane - 10-09-2012 Right had the turbo off again. My guess is now at weak actuator. Can pull it about by hand pretty easy, compared to other actuators I have lying around which are quite stiff. RE: limited boost out of t25 - strictly_perv - 10-09-2012 I swear some people have fitted the T2 ones on T25's, that may help, if not crack out the welder! RE: limited boost out of t25 - zx_volcane - 10-09-2012 I'm cracking out a different turbo ![]() Would have had it on today but having a mare trying to get an oil feed made up with an m10 banjo on the end, been to 3 hydraulic places with no joy :/ ffs it can be done! RE: limited boost out of t25 - strictly_perv - 10-09-2012 (10-09-2012, 08:26 PM)zx_volcane Wrote: I'm cracking out a different turbo I take it it's not another T25 going on? RE: limited boost out of t25 - zx_volcane - 10-09-2012 (10-09-2012, 08:28 PM)strictly_derv Wrote: I take it it's not another T25 going on? It may go back on the silver one, but I've got a new toy for the black one RE: limited boost out of t25 - CJ_Derv - 12-09-2012 You wont be dissapointed lol
RE: limited boost out of t25 - zx_volcane - 12-09-2012 (12-09-2012, 12:17 PM)CJ_Derv Wrote: its not the td04 - thats for the silver one (this is getting confusing)Think they tried to deliver the adaptor plates today, but they didn't bother ringing the door bell and I've got a card. RE: limited boost out of t25 - CJ_Derv - 13-09-2012 (12-09-2012, 03:34 PM)zx_volcane Wrote:(12-09-2012, 12:17 PM)CJ_Derv Wrote: ahh im easily confused lol, ahh good at least they left a card i use these a lot and havent had a problem let me know if any problems bud
RE: limited boost out of t25 - Olly_p - 04-11-2012 did you ever get you turbo above 20psi im having the same problem only reaching 22psi RE: limited boost out of t25 - zx_volcane - 04-11-2012 Weak actuator RE: limited boost out of t25 - Olly_p - 04-11-2012 what are you running now RE: limited boost out of t25 - zx_volcane - 04-11-2012 Lol, I'm several turbos beyond now
Re: limited boost out of t25 - Olly_p - 04-11-2012 Ahhhh fair one
