Anyone help? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: Anyone help? (/showthread.php?tid=4492) |
Anyone help? - Bananalad - 27-06-2012 Friend of mine broke the hard plastic heater pipes entering the bulk head, how do i go about taking another set off in the scrap yard without breaking them too? Thanks RE: Anyone help? - spike2002 - 27-06-2012 Take the metal retaining clip off then inbetween the two pipes is a bit of plastic sticking out you push that right i think it is. Its like a clip that holds the pipes in while holding the clip across gently putt on the plastic housing untill the pipes come out They can be quite stiff to get out due to the o rings giving a good seal
RE: Anyone help? - Bananalad - 27-06-2012 I think thats how he was taking them out but he managed to break them Thanks for that! Anyway i can do it without using them pipes do you know?
RE: Anyone help? - spike2002 - 27-06-2012 You can join the 2 pipes together to bypass the heater matrix but then you wont have any hot air in the car rite pita in winter. Ive also read somwhere that its not to good for the engine either when i removed mine the other day i held the clip in and wiggled the plastic housing left oTo right while pulling gentle done the trick for me ![]() All i can say is take ur time be gentle and they will come out in one piece
RE: Anyone help? - Ben Jay - 27-06-2012 Yea like here... http://306oc.co.uk/forum/thread-4363.html RE: Anyone help? - Bananalad - 27-06-2012 I have the heater matrix out at the moment thats why that pipe was broke in the process ![]() Ill have a go at that thanks
RE: Anyone help? - spike2002 - 27-06-2012 Good luck mate
RE: Anyone help? - Matt - 27-06-2012 Pipes are easy as fook to do. I sorted mine in 1hour RE: Anyone help? - Bananalad - 27-06-2012 Easy taken off yeah?
RE: Anyone help? - mark_airey - 27-06-2012 (27-06-2012, 08:08 AM)R45_ODV Wrote: You can join the 2 pipes together to bypass the heater matrix but then you wont have any hot air in the car Joining the 2 pipes together effectively bypasses the half the cooling system as you remove the resistance from the cooling system, if you block them off you hot spot the head where the heater matrix pipes would normally exit the head due to there being no flow..................... Blocking them up is OK as a temp measure if you have a leaking matrix providing that you drive sensibly and replace the matrix ASAP Read the link that BenJay posted
RE: Anyone help? - Bananalad - 27-06-2012 I was thinking would it be hard to seal them two pipes i broke? RE: Anyone help? - mark_airey - 27-06-2012 (27-06-2012, 08:28 AM)Bananalad Wrote: I was thinking would it be hard to seal them two pipes i broke? Cut hose, bung with anything which fits (I suggest part of a broom handle shaved down to the correct size to fit) and then jubilee clip it into place................. RE: Anyone help? - Bananalad - 27-06-2012 I have the dash out of my car and and new matrix ordered, im not bunging it up
RE: Anyone help? - mark_airey - 27-06-2012 (27-06-2012, 08:42 AM)Bananalad Wrote: I have the dash out of my car and and new matrix ordered, im not bunging it up Sorry, I was just replying to your vague question directly above my post, wasn't sure if it was aimed at me or not?
RE: Anyone help? - Bananalad - 27-06-2012 I wasnt sure if you read the thread or not Is it out of the question going to peugeot for the parts? Because i was thinking if i got a second hand one would the o rings seal tight again? Last thing i want is a leak
RE: Anyone help? - mark_airey - 27-06-2012 (27-06-2012, 08:50 AM)Bananalad Wrote: I wasnt sure if you read the thread or not Of course I haven't fully read every post, I'm at work so skim reading FTL as normal ![]() The "O" rings should seal again fine, I have never had any problems getting them to re-seal anyway, the problem is normally getting them to go back into the fitting on the matrix, but then they are just standard "O" rings so it should be pretty easy to get some replacements if your having trouble, peugeot themselves probably sell them for not a lot TBH
RE: Anyone help? - Bananalad - 27-06-2012 Thanks mark! Appreciate it! I thought i read somewhere that the hard plastic pipes were expensive from peugeot.. Anyone have a part number? RE: Anyone help? - spike2002 - 27-06-2012 (27-06-2012, 08:28 AM)Bananalad Wrote: I was thinking would it be hard to seal them two pipes i broke? If you have broke the plastic connector then youve got no chance mate
RE: Anyone help? - Bananalad - 28-06-2012 Got the heater matrix this morning, its a nissens, i know for the main radiator this is a good make but what about the heater matrix? I also got the plastic connector with it
RE: Anyone help? - mark_airey - 28-06-2012 (28-06-2012, 10:23 AM)Bananalad Wrote: Got the heater matrix this morning, its a nissens, i know for the main radiator this is a good make but what about the heater matrix? I also got the plastic connector with it Its still a radiator for the transfer of heat...........as in exactly the same just smaller, and if by "the plastic connector" you mean the part that you connect the hoses to on the bulkhead then yes.............if you didn't have that attached it would be really hard to connect really wouldn't it! what with it being part of the matrix and all I would have been really disappointed if I didn't get it with the matrix
RE: Anyone help? - Bananalad - 28-06-2012 (28-06-2012, 10:27 AM)mark_airey Wrote:(28-06-2012, 10:23 AM)Bananalad Wrote: Got the heater matrix this morning, its a nissens, i know for the main radiator this is a good make but what about the heater matrix? I also got the plastic connector with it I know what it does But would it be better going to peugeot and paying twice as much for a valeo?? Or is a nissens heater matrix a good brand is what im trying to say You have no idea how many parts i buy and they expect you to use old bits along with it ![]() Now last thing is this [attachment=1589] [attachment=1590] Can i get rid of the connector in the engine bay and use some copper pipe, jubilee clips and hard rubber pipes to bodge it? Or is that a bad idea?
RE: Anyone help? - mark_airey - 28-06-2012 Nissens is a good make and just get some more hoses really not worth bodging that! RE: Anyone help? - Bananalad - 28-06-2012 The trouble is getting new hoses :/ Do i have to get the whole hose or just the plastic bit thats broke? RE: Anyone help? - mark_airey - 28-06-2012 Whole hose, just get one from a scrap yard or start a wanted thread
RE: Anyone help? - Bananalad - 28-06-2012 Thanks very much mark
