Help Please!!!! - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Help Please!!!! (/showthread.php?tid=3731) |
Help Please!!!! - psamk1 - 27-05-2012 Hi all! I'm from Portugal and "new" in this forum and I hope someone can help me... so... the big problem is is: I replaced the engine of my peugeot 306 1.8d by an engine of a Peugeot 205 XAD turbo (1.8DTurbo). The injection pump broke down so I switched to a pump from a citroen xantia 1.9Dturbo 92Hp (bosch VE R 445-2 NR 0460494342) and bosch injectors of 175bar. Everything is installed correctly but the problem is that it makes too much smoke. I've tried adjust the amount of diesel in max fuel screw and end up with less smoke but with a terrible performance. Have followed the guide "Guide: Bosch pump setup and tuning" of Dan but can not get any good result. I do not know what to do anymore. The problem is that the pump is wrong for this engine? Many thanks in advance! Help Please!!!! - Matt - 27-05-2012 Whooaaaaaa a 1.8d?! Wtaf is one of those. Sorry not very helpfull lol Re: Help Please!!!! - ginge191 - 27-05-2012 Firstly, what colour is this smoke? Re: Help Please!!!! - psamk1 - 27-05-2012 The smoke is dark... not completely black... but after the turbo start winning more pressure the smoke disappears Re: Help Please!!!! - mark_airey - 27-05-2012 that sounds like you have too much fuel low down to make up for higher up, do you have the LDA (UFO shaped thing on top of the pump) connected to the boosted pipework? Re: Help Please!!!! - psamk1 - 27-05-2012 Yes, everything is connected correctly, in this case to intercoller (conventional top engine mount) Re: Help Please!!!! - mark_airey - 27-05-2012 It sounds like you are getting too much fuel low down in the revs so have you made any changes to the LDA setting its self? Have any other modifications/changes been made to the pump? Also, how much boost are you running? Re: Help Please!!!! - psamk1 - 27-05-2012 The turbo boost is about 0,9 - 0,95 at 3500rpm and any modifications was made in the pump except the max fuel screw that had some kind of seal apart from that the pump is intact. I just rotate the lda to minimum fuel compensation but was useless and turned again to his original position. Re: Help Please!!!! - psamk1 - 27-05-2012 Hi again! is possible that this pump is inadequate for this engine? As I said before, the engine is a 1.8DT and the pump came from xantia 1.9DT. Any guess? Re: Help Please!!!! - Dum-Dum - 27-05-2012 I think you want to turn the LDA to the steepest slope for maximum compensation then turn the maximum fuel down a bit more. Is the LDA free to travel and is the black disc / diaphram at the top of the LDA intact as sometimes they have holes in meaning that the LDA dosent work effectively. May be the wrong thing to suggest as its hiding the problem rather than fixing it but you could just wind the wastegate up a bit more for some extra boost to burn the fuel. |
