problems - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Guides (https://www.306oc.co.uk/forum/forumdisplay.php?fid=9) +--- Thread: problems (/showthread.php?tid=37243) |
problems - amj32 - 08-02-2019 i have a d turbo engine from a xantia. fitted with a mechinacal bosch pump havnt had it apart but bought it as a gov modded and pin grind was going great for a couple weeks now it pull as normal till it hits aprox 2500rpm bit of black smoke up till the boost starts to drop then none . dont have a rev counter but 60 mph 5 gear starts dropping from 20psi gradually then boost drops off as if its not getting fuel wont pull over 75 mph . new filter lines blew back to tank . thinking pump internals gov spring /rack ? . has anyone had similar issues or solved any advice ? thanks . Sent from my SM-G920F using Tapatalk |
