Hdi remap - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Hdi remap (/showthread.php?tid=35420) |
Hdi remap - Matt - 02-01-2017 Feels weird posting in this section haha. So just picked up a hdi, has a stainless straight pipe but still has cat It apparently has had a remap, but doesn't feel that quick. What sort of times should I expect 30-70 for a stage 1 and the exhaust mentioned? As far as I'm aware it has no other modifications, just wondering if it is mapped or not. Bonus if it isn't as it'll be quick than this
Hdi remap - bashbarnard - 03-01-2017 Just youtube it there are a few on there. I thinks toms306 actually done a few videos from memory. Also you may just have a dead maf. Seems to ve super common lus actually went recently. Disconnect it and see if it feels any diffrent Sent from my iPhone using Tapatalk RE: Hdi remap - Matt - 04-01-2017 Will give it a shot mate. I just went from 170bhp to 120bho I was expecting slow as its diesel, but this just doesn't feel right RE: Hdi remap - allye - 04-01-2017 You've also gone from 145ft/lb to 200ft/lb, if it doesn't feel right it probably isn't. In my experience of HDI's they can feel completely different between cars. RE: Hdi remap - DeeTurbo - 04-01-2017 Don't forget the HDI has a cold map that restricts it loads before it warms up. I hate going straight from my '6 to the HDI. RE: Hdi remap - ginge191 - 05-01-2017 Test it against mine; its standard RE: Hdi remap - MY95 - 05-01-2017 (04-01-2017, 10:47 PM)DeeTurbo Wrote: Don't forget the HDI has a cold map that restricts it loads before it warms up. Never knew this but interesting, wonder where theres more info on this. Until what temp does the 'cold map' work? RE: Hdi remap - Piggy - 05-01-2017 Doesnt restrict it that much, if at all tbh Edit: see Ruan. Lol RE: Hdi remap - Ruan - 05-01-2017 (05-01-2017, 05:41 PM)MY95 Wrote:(04-01-2017, 10:47 PM)DeeTurbo Wrote: Don't forget the HDI has a cold map that restricts it loads before it warms up. There isn't a 'cold map'. There's correction at part throttle to increase injection quantity to overcome the increased internal friction so it'll accelerate at roughly the same rate... There's also correction to many other aspects (Start of injection, railpressure, pilot timing and quantity etc...) There isn't any function to reduce power when the engine is cold... Nor any sudden switching when things warm up - it's all blended across the entire temperature range. Any lack of power felt is purely down to the fact that the internal friction is higher and the combustion quality isn't as good as the cylinders aren't up to temperature. RE: Hdi remap - DeeTurbo - 06-01-2017 Just goes to show you shouldn't believe everything you read off the net lol Why would you say our HDI's suffer so badly when cold because almost all cars suffer higher internal friction with cold oil and cylinders, is it because they were the early direct injected and common rail technology? |
