HP pump spacer - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: HP pump spacer (/showthread.php?tid=34249) |
HP pump spacer - DeeTurbo - 03-06-2016 How much of an issue would it be if spacer number 9 was missing? I've got a feeling it might have been missed when I had the pump replaced under warranty years back. ![]() I found the spacer when I replaced the alternator. RE: HP pump spacer - Poodle - 04-06-2016 Clearly not much of an issue if it's still all working fine several years later.
RE: HP pump spacer - DeeTurbo - 04-06-2016 I thought it might be causing the belt too tight sound because of the pump being out of alignment, if it is with the missing spacer? Sent from my Nexus 4 using Tapatalk RE: HP pump spacer - JTaylor2005 - 04-06-2016 Looking at the drawing it looks like it would push the pump further to the right (as u look into engine bay) Which would move the pulley across to the right as well? |
