EGR disconnect/unplug on XUD? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: EGR disconnect/unplug on XUD? (/showthread.php?tid=32975) |
EGR disconnect/unplug on XUD? - Dazecoop - 07-01-2016 Done a bunch of reading & looking around, came across this (10-01-2014, 01:20 PM)andywhy Wrote: If you want to disable the EGR, the easiest way I found was to with the ignition on and engine off, open the throttle to full so the microswitch activates and then disconnect the EGR plug. It'll stay in the last position it was at. I got a lot of power back by doing that but it only worked if in the position when the throttle is open. Can anyone verify this works & if this is worth doing? Secondly, can anyone verify which plug & where it is located to disconnect? It'd be cool to get a little more power from my D Turbo with such a simple & easy job!
RE: EGR disconnect/unplug on XUD? - Mattcheese31 - 07-01-2016 That is for hdi afaik mate, xud just needs turbo and Mani blocking off
RE: EGR disconnect/unplug on XUD? - Dazecoop - 07-01-2016 (07-01-2016, 04:42 PM)Mattcheese31 Wrote: That is for hdi afaik mate, xud just needs turbo and Mani blocking off Is it? The thread its from is talking about an XUD engine (http://306oc.co.uk/forum/showthread.php?pid=375935) Blanking inlet & mani means blanking plates etc? I can't find any for sale anywhere. Is it a custom job? ![]() This thread also talks about a plug near/behind battery to disable EGR on XUD engine http://www.theywhoshallnotbenamed/forum/threads/121844-DTurbo-EGR-disable RE: EGR disconnect/unplug on XUD? - Mattcheese31 - 07-01-2016 Hmmmm maybe so then, last two xud's I owned were early non egr engines, current one has it though. RE: EGR disconnect/unplug on XUD? - Midnightclub - 07-01-2016 There's literally thousands available on eBay dude If unplugging them is a thing on the XUD's then you still have the possibility it's stuck open which unplugging won't help RE: EGR disconnect/unplug on XUD? - Dazecoop - 07-01-2016 (07-01-2016, 04:54 PM)Mattcheese31 Wrote: Hmmmm maybe so then, last two xud's I owned were early non egr engines, current one has it though. Ah fair, that might make sense. I'm tempted to go try it! How can I tell if its actually worked? I mean, I hope its suddenly like having an extra couple turbos, but somehow I doubt it ![]() (07-01-2016, 04:55 PM)Midnightclub Wrote: There's literally thousands available on eBay dude I'd have thought that too, but... ![]() Unless I'm doing something massively wrong or eBay is broken. Kinda strange?
RE: EGR disconnect/unplug on XUD? - Midnightclub - 07-01-2016 Search link: http://www.ebay.co.uk/sch/i.html?_odkw=pegueot+egr+blank&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xpeugeot+egr+blank.TRS0&_nkw=peugeot+egr+blank&_sacat=0 Actual advert: http://www.ebay.co.uk/itm/527-Egr-Vave-Blanking-Block-Plate-Gasket-Citroen-Peugeot-2-0-HDi-/221484012501?fits=Car+Make%3APeugeot&hash=item339179d3d5:g:~BAAAOSwHaBWi7Mh RE: EGR disconnect/unplug on XUD? - Dazecoop - 07-01-2016 (07-01-2016, 05:10 PM)Midnightclub Wrote: Search link: http://www.ebay.co.uk/sch/i.html?_odkw=pegueot+egr+blank&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xpeugeot+egr+blank.TRS0&_nkw=peugeot+egr+blank&_sacat=0 Advert link says its for 2.0 HDI? RE: EGR disconnect/unplug on XUD? - Midnightclub - 07-01-2016 Honestly, they all look pretty much identical and I'd assume it'd be the same. But I'm sure someone else can confirm RE: EGR disconnect/unplug on XUD? - Jonny81191 - 07-01-2016 Dave, buy a gasket as a template and I'll make you a blanking plate. RE: EGR disconnect/unplug on XUD? - Dazecoop - 07-01-2016 (07-01-2016, 05:49 PM)Jonny81191 Wrote: Dave, buy a gasket as a template and I'll make you a blanking plate. Yeah? That'd be cool, thanks dude! I'll chat to you about that
RE: EGR disconnect/unplug on XUD? - Ruan - 08-01-2016 Chemi metal and two pence pieces ftmfw. |
