Decat for Citroen ZX 1.9TD - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Decat for Citroen ZX 1.9TD (/showthread.php?tid=30330) |
Decat for Citroen ZX 1.9TD - kee616 - 05-05-2015 Hello, does anyone know if the 306 decat pipe can be used on the Citroen zx? i know the cars are very similar in design but are the exhaust the same? thanks RE: Decat for Citroen ZX 1.9TD - Mattcheese31 - 05-05-2015 Some will know more than me however, I do know the exhaust differs between zx and 306 not sure on the downpipe though
RE: Decat for Citroen ZX 1.9TD - Anton - 05-05-2015 Hello, No its different. However I have a lovely turbo to backbox exhaust system in my garage if you're interested? RE: Decat for Citroen ZX 1.9TD - kee616 - 05-05-2015 (05-05-2015, 07:10 AM)Anton Wrote: Hello, Hmm hadn't thought about doing the whole exhaust but go on ![]() Got any pictures? And how does it sound? RE: Decat for Citroen ZX 1.9TD - welshpug - 05-05-2015 trouble with the earlier non cat system is that its only a two piece system not three piece like the cat cars, the only part which is the same as a 306 is the cat, from the cat bsck under the tank to the tailpipe is different. no hanger on the middle box, bends under the tank different enough for the 306 system to hit the tank, and the rear hangers sit at 90 degrees to the 306. RE: Decat for Citroen ZX 1.9TD - Anton - 05-05-2015 (05-05-2015, 11:29 AM)kee616 Wrote:(05-05-2015, 07:10 AM)Anton Wrote: Hello, I haven't got any pictures but it looks like an exhaust haha. Its not very old, I had the midbox removed and a straight pipe welded in its place. Its got a standard backbox attached too if you wanted that as well. I can get pics if you like. 07842257681 RE: Decat for Citroen ZX 1.9TD - kee616 - 05-05-2015 Okay mate messaged you
RE: Decat for Citroen ZX 1.9TD - kee616 - 13-05-2015 (05-05-2015, 11:42 AM)welshpug Wrote: trouble with the earlier non cat system is that its only a two piece system not three piece like the cat cars, the only part which is the same as a 306 is the cat, from the cat bsck under the tank to the tailpipe is different. RE: Decat for Citroen ZX 1.9TD - kee616 - 13-05-2015 PG483L is this the Part number I need for the down pipe? Thanks |
