Refurbing dead bosch - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: Refurbing dead bosch (/showthread.php?tid=30226) |
Refurbing dead bosch - bashbarnard - 27-04-2015 Ive got a dead Bosch pump sitting under my bench at work and a 414 11mm pump there as well. The 414 should be fine as all I need is the head. The standard pump though has not been used in 5 years and hasn't had fuel kept in it. Also has been confirmed dead by previous owner. Any chances of getting it back into action? Or is it worth me just buying a known working one. RE: Refurbing dead bosch - zx_volcane - 27-04-2015 tolerances inside are very tight - so if you have any corrosion inside its generally dead save the hassle and pick up a known working one RE: Refurbing dead bosch - bashbarnard - 27-04-2015 That's fair enough. Just thought id ask. I'll keep it for spare parts. No harm having it stripped down though to have a look at some point this week. RE: Refurbing dead bosch - darrenjlobb - 27-04-2015 Hm depends if moisture has got in there, if its dry dry, itl likely be fine / just stuck together with tar, good cleanup and itl go...only way is to open it up... |
