Turbo replacement. - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Turbo replacement. (/showthread.php?tid=2924) |
Turbo replacement. - Lukeey - 20-04-2012 Ok I think my turbo is on its way out. :o what I was wondering is which turbo will be best and easiest to replace it. I know the simple option would be to just replace it like for like. But I thought whilst taking it off I might upgrade it. At the same times think I will be doing a Bosch fuel pump too. So which would be the easiest to Bolt on? Re: Turbo replacement. - Ricky - 20-04-2012 Depends what you have in the first place. Although, all four of the standard turbo's are simple bolt on jobs as long as they come complete with oil lines. T2 would be the best choice. Re: Turbo replacement. - strictly_perv - 20-04-2012 If you have a K03 then a GT15 would be the easiest or if you have a K14 than a T2 would be the easiest. T2 is the one you want for a standard turbo. Re: Turbo replacement. - mark_airey - 20-04-2012 K14 is just as good as the t2 tbh
Re: Turbo replacement. - Ricky - 20-04-2012 mark_airey Wrote:K14 is just as good as the t2 tbh As long as you fit a manual boost controller to if before you fit it
Re: Turbo replacement. - mark_airey - 20-04-2012 Ricky Wrote:mark_airey Wrote:K14 is just as good as the t2 tbh I can't comment on this. My wategate is welded shut, lol Re: Turbo replacement. - Lukeey - 20-04-2012 What's the easy way to find put what turbo I have. 1997 dturbo. Will any garret t2 do or should I get a specific one? Re: Turbo replacement. - strictly_perv - 20-04-2012 Most likely a K03 but it's French so you never know. Yeah try get a Peugeot/Citroen one. Re: Turbo replacement. - Ricky - 20-04-2012 At a guess I would say you have a K14, it's usually only the very late ones with the K03/GT15, but with these they can vary quite a lot. You need to have a look underneath, google kkk k14 for a picture, the funny wastegate bit will stand out. You will need a T2 from a 306. Re: Turbo replacement. - 4WayDiablo - 20-04-2012 Yeah don't do what I done and go like for like. Admittedly I went for another t2 but you may as well go for something better along the lines of td04 or similar Re: Turbo replacement. - strictly_perv - 20-04-2012 Ricky Wrote:At a guess I would say you have a K14, it's usually only the very late ones with the K03/GT15, but with these they can vary quite a lot. You need to have a look underneath, google kkk k14 for a picture, the funny wastegate bit will stand out. The turbo's fitted to all the other Pug/Cit XUD's will fit aswell though Re: Turbo replacement. - Ricky - 20-04-2012 strictly_derv Wrote:Ricky Wrote:At a guess I would say you have a K14, it's usually only the very late ones with the K03/GT15, but with these they can vary quite a lot. You need to have a look underneath, google kkk k14 for a picture, the funny wastegate bit will stand out. I thought the exhaust elbow was a different angle on some of them? Turbo replacement. - Jake - 20-04-2012 If your turbo blows you have to go bigger, it's the law! Re: Turbo replacement. - Lukeey - 21-04-2012 Well which would be the easiest bigger turbo to fit'? Re: Turbo replacement. - 4WayDiablo - 21-04-2012 Lukeey Wrote:Well which would be the easiest bigger turbo to fit'?Td04 hl 13t Basically a Subaru impreza turbo. You'll need to get an adapter plate made from approx 8mm and some custom oil lines. Then enjoy double (from standard) power Re: Turbo replacement. - Lukeey - 21-04-2012 Adaptor plate? You mean just a 8mm spacer between? Any idea where I can get the oil lines ? Re: Turbo replacement. - Dan! - 21-04-2012 I'd go for a TD04L over a HL tbh... Re: Turbo replacement. - 4WayDiablo - 21-04-2012 I've not done it myself so I dunno where to get the custom oil lines from Turbo replacement. - Jake - 21-04-2012 HL would be poo I recon, most hydraulics places will be able to make Hoses up for you. Re: Turbo replacement. - mark_airey - 21-04-2012 T25 is easier to fit because IIRC you can use the same oil line as the T2 ![]() TD04HL is a tiny turbo and isn't the impreza one Phill, the TD04L is the scooby one, the HL is found on shoguns amongst other things IIRC Re: Turbo replacement. - Lukeey - 21-04-2012 Yeh did some looking and HL can be found on Volvo's it's the L from the impreza. It's just I'm having to do a lot of work on it now and the list and the cost are getting bigger.mjust did the wheel bearings. Next is cam belt water pump. And I think a new fuel pump. But now I believe me oil seals have gone on the turbo. So ideally I would like a bigger turbo but if I need to replace it quickly a std one will have to do what is the max sort of power I could get out a std on with a Bosch pump & lda mod? Re: Turbo replacement. - mark_airey - 21-04-2012 You could get it up to 130 or 140 hp I would think on a standard turbo ![]() If you need a standard One then I have a couple
Re: Turbo replacement. - silverzx - 21-04-2012 mark_airey Wrote:You could get it up to 130 or 140 hp I would think on a standard turbo If you got a T2 going free... :mrgreen: Re: Turbo replacement. - mark_airey - 21-04-2012 I have nothing going for free.............I do have a T2 but its my old one and as a result it is f*cked!!
