my 306 1.9 tdi meridian - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Other Marques (https://www.306oc.co.uk/forum/forumdisplay.php?fid=38) +--- Forum: Technical (https://www.306oc.co.uk/forum/forumdisplay.php?fid=40) +--- Thread: my 306 1.9 tdi meridian (/showthread.php?tid=29086) |
my 306 1.9 tdi meridian - sb194114 - 04-02-2015 So after having my car a week or so and getting used to the fact I drive a diesel these day iam noticing a few bits and pieces that require attention, not to worry would have been a lot worse if one off the previous owners hadn't put so much money into it. Unfortunately the owner who bought it from him seems to have failed on a few points causing slow lumpy straps in the morning and no real heat from the heaters after the engine temp rising significantly while waiting at a drive through the other day I checked the coolant level and found it to be low so decided on topping it up well 2 litres off anti freeze coolant mix later and my heaters are a bit warmer but still systems not full another trip to the supplier for me. This morning I blew a headlight 16 gbp for a bulb damm!! But turns they are on offer 2 for 1 so just got 2 Anyway all in all once I have the other 4 or so litres off coolant in and a good run iam confident car will be nearer it's former glory, ohh and I got the windscreen fixed as well RE: my 306 1.9 tdi meridian - sb194114 - 04-02-2015 Sorry wrong section have reposted in correct section please remove RE: my 306 1.9 tdi meridian - Mattcheese31 - 04-02-2015 Make sure you bleed the coolant properly, think there is a guide in the guides section, it's slightly awkward and very important on these engines
