GTI - 6 Head measuring - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: GTI - 6 Head measuring (/showthread.php?tid=26541) |
GTI - 6 Head measuring - j_carter - 07-09-2014 Hi. Ive had a search on the forum but cant really find an answer to my question.. Could somebody please tell me exactly how to measure a head to tell if its ok for a re-skim? and also what the measurement of a standard head is? Pictures would be brilliant.. thanks in advance RE: GTI - 6 Head measuring - Eeyore - 08-09-2014 oh god i cant remmeber the details now. Its not much! If they have to take the valves out to skim it then its too much! There are two markers one at each end of the head. If there is a decent amount left in those then it should be fine. RE: GTI - 6 Head measuring - cully - 08-09-2014 standard head measurement is 137mm +/- 0.05. minimum height is 136.8mm +/- 0.05. measured between the cam ladders and the head face [attachment=18841] Peugeot Head Gasket MLM std 1.2mm 0209Z2 £45.84 Peugeot Head Gasket fiber 1.4mm 0209T9 £47.95 lots of info with part numbers here from my build http://306oc.co.uk/forum/thread-17479.html? RE: GTI - 6 Head measuring - j_carter - 09-09-2014 you sirs, are gentlemen! thank you very much.. |
