mystery plugs and a thing - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: mystery plugs and a thing (/showthread.php?tid=26283) |
mystery plugs and a thing - mackat - 25-08-2014 While having a mooch for the map in the XSI, I came across a couple of unplugged cables and a mystery thing. Would anyone know what they are? The thing and cable#1: [attachment=18592] Cable#2: [attachment=18593] [attachment=18594] RE: mystery plugs and a thing - Grant - 25-08-2014 "Mystery thing" is the innetia switch. Yours looks a bit chewed. Could be worth taking a look at. Number two needs to be a bit more specific. Three is unused on all 306's IIRC. RE: mystery plugs and a thing - Eeyore - 25-08-2014 Yeh that innertis switch has a ball bearing in it which bridges the circuit. If you're in a crash it cuts the power to something. RE: mystery plugs and a thing - mackat - 25-08-2014 aha.. so thats what it is..! I was happily pushing the button while trying to work out what it was. I think the previous owner had a mouse or something living under the bonnet, a few places have been chewed. Cable#1 with the inertia switch goes through the hole into the firewall of the car.. will have to trace it another day. picture#2 and 3 are the same cable, was found hanging where I've circled in red right under the inlet manifold. Is it normal to have plugs disconnected? I think I've probably found 4-5 which I didn't take photos of RE: mystery plugs and a thing - Grant - 25-08-2014 Ah sorry, didn't see the plug down there. Thought you were pointing at the inertia switch. (25-08-2014, 08:36 PM)SRowell Wrote: Yeh that innertis switch has a ball bearing in it which bridges the circuit. If you're in a crash it cuts the power to something. Fuel relay. |
