Best way to get front hub nut off - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: Best way to get front hub nut off (/showthread.php?tid=26116) |
Best way to get front hub nut off - rocker8742 - 22-08-2014 Currently got it on the floor with a centre less wheel and my longest 1/2 bar and can't shift it RE: Best way to get front hub nut off - powerandtorque - 22-08-2014 Windy/impact gun or a bigger bar
RE: Best way to get front hub nut off - Toms306 - 22-08-2014 (22-08-2014, 01:30 PM)powerandtorque Wrote: Windy/impact gun or a bigger bar This!! Never had an issue removing them with an impact gun... Best way to get front hub nut off - rocker8742 - 22-08-2014 Only gun I've got is rated to 195nm probably not enough if I can't shift it with the bar lol RE: Best way to get front hub nut off - Toms306 - 22-08-2014 Theyre supposed to be 360Nm iirc, so that wont help lol, I take it its a battery one? My mains one is rated at 450Nm! Best way to get front hub nut off - rocker8742 - 22-08-2014 Fook lol probably why the gun was useless RE: Best way to get front hub nut off - cully - 22-08-2014 could give it a battering with my gun no promises it will shift it though Best way to get front hub nut off - Frosty - 22-08-2014 Where's it to tom? You can borrow my gun if need be. I'm passing your way later on Best way to get front hub nut off - rocker8742 - 22-08-2014 Got there in the end just had to extend the bar a bit RE: Best way to get front hub nut off - Curt - 22-08-2014 If you can't move something and there's access, the answer is always more leversge
RE: Best way to get front hub nut off - ADV_93 - 22-08-2014 mate with foot on brake and breaker bar with scaffold pole over it RE: Best way to get front hub nut off - Tom - 22-08-2014 ^^ Was gonna say, 5ft of scaffold bar works for me. |
