Engine wobble - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: TU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=18) +--- Thread: Engine wobble (/showthread.php?tid=26033) |
Engine wobble - Bigyin306 - 19-08-2014 Hi guys I have a 2001 1.4 306 the problem is when I'm driving under load I can feel the car wobbling from the front and the gear nob is going nuts lol, was told it could be the inner parts of the drive shafts where they go into the gear box, has anyone else had this problem? Cheers Ross RE: Engine wobble - powerandtorque - 19-08-2014 Yes inner CV's can cause excessive wobbling/shaking under load. Check the state of the engine/gearbox mounts as well, as excessive movement in these thanks to worn or broken mounts will make matters worse. RE: Engine wobble - Bigyin306 - 19-08-2014 (19-08-2014, 03:11 PM)powerandtorque Wrote: Yes inner CV's can cause excessive wobbling/shaking under load. Cheers bud just wanted to make sure want I was told was right |
